Random ticking
Old Nov 19, 2007 | 05:08 PM
Sampsonite987's Avatar
Default Random ticking
My 5th gen makes a random ticking noise at around 3000rpm. It doesn't matter if it is under load or not. It isn't real loud, but I notice it and it bugs the crap out of me. What do you think, rocker arms? Valves?
Old Nov 19, 2007 | 05:10 PM
ECX's Avatar
ECX
* B A N N E D *
Pop the hood and have someone rev it up, use a screwdriver and put it on your valve cover, put your ear to it.
Hopefully it's not an early sign of rod knock which is what I ended up finding out about my "ticking" noise.
Old Nov 19, 2007 | 05:11 PM
Default Re: Random ticking (Sampsonite987)
Also, I searched and a lot of the threads state that it is a typical Honda sound. I am new to the DOHC VTEC realm, I am used to the sounds from SOHC VTEC/Non VTEC. It just concerns me a bit,
Thanks in advance
Old Nov 19, 2007 | 05:12 PM
Default Re: (ECX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECX &raquo;</TD></TR><TR><TD CLASS="quote">Pop the hood and have someone rev it up, use a screwdriver and put it on your valve cover, put your ear to it.
Cool, will do.
Like I said, it isn't very loud, I think I am just paranoid but I will try that for sure.
Thanks for the quick response.
Old Nov 19, 2007 | 05:19 PM
ECX's Avatar
ECX
* B A N N E D *
Default Re: (Sampsonite987)
No problem. I'm by no means not as experiencedd as the other guys but my instructor at school told me about that little trick. Could be it just needs a valve adjustment, who knows.
Old Nov 19, 2007 | 05:45 PM
dagle's Avatar
Default Re: (ECX)
do u have any idea where it's coming from? i would think the valves needing adjustment would be ticking at idle.. can it be clutch chatter? (is that the term?) cuz my car makes a noise under similar conditions on cold days only. I know it's not valves for me because my valves already tick lol. just throwing the suggestion out there, i def hope you don't have rod knock o_o;
Old Nov 19, 2007 | 05:54 PM
Default Re: (dagle)
It is an SS Auto, no clutch. I don't think it is rod knock, it sounds to me like it may be coming from the head but I'm not sure. BTW the engine has 128k on it.
Old Nov 19, 2007 | 06:12 PM
ECX's Avatar
ECX
* B A N N E D *
Hmm. That's what I thought also. Not trying to scare you into thinking that though...
Is it coming from behind the motor like where the intake manifold is? Is it loud or just a literal tick?
Old Nov 19, 2007 | 06:19 PM
Default Re: (ECX)
I can't tell for sure exactly where it is coming from yet, I will check that tomorrow. As for it being loud, no, it isn't loud. I have only had the car for about 2 weeks and I don't know if it has been doing it the entire time. You know when you get a new vehicle after a while you start to notice things that you didn't before. It could probably use a valve adjustment, the car has had only 2 owners (3 including me) and the guy that had it before me does not seem the type to have had the valves adjusted, but who knows.
obuhmyuh
Feb 2, 2008 12:00 AM
illicit_kustomz
Nov 8, 2007 12:10 PM
Touge Tuning
Oct 15, 2006 11:04 AM
mrbsponge
Jan 28, 2004 01:26 PM
whatcivic
Jun 6, 2003 07:13 AM
