HID Problem. Please help.
Old Dec 11, 2007 | 09:57 AM
ptj20's Avatar
Default HID Problem. Please help.
Hi. I just installed new HID kit on my 5th gen prelude but the light shines really upward and blinds the hell out of people in front of me. They get so pissed off. Also people across me waiting for signals high beam me and flick me off. Does anyone know how to fix that problem?
Old Dec 11, 2007 | 10:34 AM
Inextricabledrvr's Avatar
Default Re: HID Problem. Please help. (ptj20)
There are a couple screws behind the headlight that you have to turn to aim the headlight.
You also have to be on a flat surface and 15-20 ft away from a wall.
What kind of kit did you buy? I have mine and they arent that bad to the point where I blind everybody and get the finger.
Good luck
Old Dec 11, 2007 | 10:36 AM
type-sexy's Avatar
adjust the level of the beam downward...there should be a bolt behind the headlight somewhere i think to level it down u tyrn it clockwise or counterclock wise
Old Dec 11, 2007 | 11:22 AM
street_ride14's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptj20 &raquo;</TD></TR><TR><TD CLASS="quote"> Just installed new HID kit, blinds the hell out of people in front of me, they get so pissed off. People across me high beam me and flick me off. </TD></TR></TABLE>
Hahaha ...... the side effect of a Plug-And-Play Hid Kit. Too much glare, everywhere. I bet you can't see **** on the road either, right ? ... I knew about this, read up on it, and seen the symptoms personally and so I went with a Retrofit instead of a PnP kit. The only cure for your disease is to take that PnP kit out and go back to OEM or do a Retrofit.
Old Dec 11, 2007 | 11:47 AM
Default Re: HID Problem. Please help. (street_ride14)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ride14 &raquo;</TD></TR><TR><TD CLASS="quote">
That is the best solution, but not everybody can afford to do a $7-800 retrofit. So, the second best option are the PnP's. You just have to aim them a bit lower and you'll be fine. Ive had mine for over 3 yrs and have no issues. And I see everything on the road 10X better than stock. Just aim them correctly
Old Dec 11, 2007 | 12:19 PM
prelude1897's Avatar
That's the best and only solution to fixing the problem. Even when you point them way down, that kills the light going outward where you want it to be instead of 5ft. in front of you. With a retrofit, you'll beable to see like 20yds in front and side of you. It's up to you. PnP kit to see 5 yds or a Retrofit to see 20+yds. Not all retrofits cost $7-$800. It all depends on what type of setup you're wanting which will determine the price of your retrofit
Old Dec 11, 2007 | 12:54 PM
mikemjohnson's Avatar
110% wrong
i sell PnP kits for a living. its all about the headlight, and all stock non-projector headlights can be properly aimed with HIDs.
the reason your lights are so misaimed is because since the plug and play no longer uses the white base that plugs into the base of your halogen, the bulb is not seated correctly and is aiming to high. a quick and actually perfect solution is to cut the top of an aluminum can off so you have the side of the can as a flat sheet of aluminum. cut a u shape out that slips over the base of the bulb so that the aluminum gets caught by the bracket on the back of the headlight that locks the bulb in, this way the bulb is seated and doesnt shine to high. PM me for more details. it sounds ghetto but if you want to be 'pro' then buy a sheet of aluminum from a store, but its still the same thing
Old Dec 12, 2007 | 01:14 PM
ptj20's Avatar
thank you so much guys. im not sure which one to try first but ill try them all.
Old Dec 12, 2007 | 01:58 PM
axlline's Avatar
Default Re: HID Problem. Please help. (mikemjohnson)
Wow using a coke can as a bandaid for plug-n-plays, Get a retrofit please.
Modified by axlline at 8:13 PM 12/12/2007
Old Dec 12, 2007 | 02:06 PM
Alex_G's Avatar
Occupy GDD
Default Re: HID Problem. Please help. (axlline)
What kelvin are your hids? non hid housing with pnp hid kit = . If you want to stop getting the finger from people then do a retro-fit.
Old Dec 12, 2007 | 03:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikemjohnson &raquo;</TD></TR><TR><TD CLASS="quote">
110% wrong
the reason your lights are so misaimed is because since the plug and play no longer uses the white base that plugs into the base of your halogen, the bulb is not seated correctly and is aiming to high. a quick and actually perfect solution is to cut the top of an aluminum can off so you have the side of the can as a flat sheet of aluminum. cut a u shape out that slips over the base of the bulb so that the aluminum gets caught by the bracket on the back of the headlight that locks the bulb in, this way the bulb is seated and doesnt shine to high. PM me for more details. it sounds ghetto but if you want to be 'pro' then buy a sheet of aluminum from a store, but its still the same thing </TD></TR></TABLE>
you're 115% wrong, cause not all stock non-projector housings can handle cheap PnP kits simply cause of all the glare they cause. About the only way of not blinding people on the street is to get 8000k and up plus aim them down all the way, but when you do that, you loose lighting onto the street. I'd much rather run 4300k bulbs through some projectors so that I can get the full affect that everyone wants when having HIDs on their car. If you put 4300k bulbs in a Prelude headlight without projectors, you'll be blinding people all the time even with your lights aimed down all the way. I know this because I once had HIDs without projectors, but this was about 4 years ago before I started doing retrofits.
Old Dec 12, 2007 | 03:11 PM
inostageh23's Avatar
there are screws on the headlight which you can adjust it to aim lower
Old Dec 12, 2007 | 03:12 PM
but i would reccommend tsx retrofitted headlights, they have a clean cutoff.
///Nick
Lighting
Apr 21, 2011 04:44 PM
paul12001
Honda Civic (2006 - 2015)
Dec 25, 2007 07:29 PM
tcontesh
Jan 27, 2006 08:35 AM
chaskim
Dec 6, 2005 09:34 PM
