92 prelude no start problem, help please
92 prelude no start problem, help please (injectors dont fire)
hi everyone i did a ton of searching but cant find anything for my problem. my car is a 92 si h23 prelude automatic 98,000 miles
i was driving it in the rain, then i stopped at a red light and when it turned green i started going but right after the car stalled out and it wouldnt start up again. also it seemed like my battery died after i got it towed back
heres what I've checked so far:
timing belt seems good (looked into oil fill to see cam spins when cranking)
i get spark, (the external coil is good)
main relay clicks (also changed to be sure)
fuel pump primes
*i get fuel pressure to the fuel rail
fuel injectors show good resistance (to spec)
fuel injector resistor box is to spec (switched with another one just in case)
*the problem seems to be that my injectors aren't firing, there is no smell of fuel inside the cylinders even when i crank with no spark plugs. But i don't have diodes to check if im getting pulse to the injectors
can anybody tell me why my injectors wouldnt fire? i was thinking maybe the distributor had a sensor go bad but i did some resistance checks and they were to factory spec. i have not tryed replacing the distributor because its expensive and i don't want to change something if it turns out it doesn't need to be changed.
can anybody give me some ideas, maybe something i missed? thanks in advance
*also the car has an alarm on it that is at least 10 years old
*Long story short: i have a 92 prelude si 4ws
it wont start. figured out that the fuel injectors werent firing. cant fix the problem.
need suggestions. thanks
Modified by sg at 3:36 PM 1/15/2008
Modified by sg at 3:40 PM 1/15/2008
fuel pump primes
Re: (bambbrose)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bambbrose »</TD></TR><TR><TD CLASS="quote">I would say the dizzy still. Did you check the cam position sensor?
When the ECU doesn't get a signal from that sensor, or the TDC sensor, it shuts off the injector circuit, which would explain your lack of fuel</TD></TR></TABLE>
that's exactly what I keep thinking, i spent days and days with a multimeter and a factory service manual checking the ecu and all fuses and sensors i can possibly think of. i don't see any other solution besides replacing the dizzy.
of course i did test it, the resistance is within spec.
right now im stuck and out of ideas so i came to see if other people think of anything that i haven't thought of yet, and thank you for your reply
Modified by sg at 3:35 PM 1/15/2008
Re: (sg)
okay i replaced the dizzy today with a brand new one. still doesnt start.
my fuel injectors arent firing. what can be the problem?
i tryed everything im about to give up and send it to the dealer, any suggestions would be appreciated
sg
09-08-2008 09:11 PM
