BRAKE QUESTION......Please help
Old Dec 17, 2007 | 06:17 PM
93sivtec's Avatar
Default BRAKE QUESTION......Please help
Hey guys and gals.....I have a 93 si,and I just recently put new ss lines in along with a new master cylinder,and while driving to day me e brake light came on for no reason......and then after about 2-3 miles it turned off, and ABS light came on.So I shut off the ignition and both lights turned off....well about 5 miles later my ebrake light came on the dash again......so I checked to make sure it wasnt pulled up a little bit,and it wasnt.Well it shut off.....but why is this happening?
I hate the dash warning lights and it bugs the heck out of me....has any1 had a similar problem in the past?Thanks in advance for the helpfull replies.
Old Dec 17, 2007 | 09:11 PM
93sivtec's Avatar
Default Re: BRAKE QUESTION......Please help (93sivtec)
ttt bump////// anybody ever hear of this?? Its crazy,maybe I need to re bleed my rear brakes.
Old Dec 17, 2007 | 09:14 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93sivtec &raquo;</TD></TR><TR><TD CLASS="quote">ttt bump////// anybody ever hear of this?? Its crazy,maybe I need to re bleed my rear brakes.</TD></TR></TABLE>
likely need to bleed the brakes.
Old Dec 17, 2007 | 09:28 PM
Hawkze_2.3's Avatar
Did you check the brake fluid? The sensor on the lid for the master cylinder will cause the brake light to come on if you fluid is low.
Old Dec 17, 2007 | 11:40 PM
93sivtec's Avatar
Default Re: BRAKE QUESTION......Please help (Hawkze_2.3)
Good call hawkze....it was a Little low,but Im not sure if that was it or not,anyway if it dosent remedy the problem than I will bleed the entire system again,and go from there.THanks again
Modified by 93sivtec at 12:50 PM 12/18/2007
feldkij
Jun 20, 2017 07:36 AM
slowls94
Apr 30, 2007 11:30 PM
UK PRELUDER
Jan 22, 2006 09:15 AM
ilikemyaccord
Jun 13, 2004 09:16 PM
Bishop Don Shizzle
Jan 2, 2004 06:23 PM
