Check Engine Light comes on randomly?
Old Dec 17, 2007 | 09:57 PM
roller3804's Avatar
Default Check Engine Light comes on randomly?
A week or so after I cleaned my EGR valve the MIL light has come on and not affected the car in anyway. When i got home to run the code, I jumped the blue service connector and the SRS light just kept flashing for over 120 times.
1994srv / jdmh22 / USDM ECU
Any ideas why it would pop up but not have a code stored?
Old Dec 18, 2007 | 12:23 AM
Acidcrakker's Avatar
Default Re: Check Engine Light comes on randomly? (roller3804)
Bump for curiosity, my SRS light has done the same thing before.
Old Dec 18, 2007 | 02:53 AM
mattsnooz's Avatar
Have you done ANY electrical work to your car at all? Cutting wires, splicing, etc.?
Old Dec 18, 2007 | 06:06 AM
shadha's Avatar
My engine light would randomly flicker, sometimes I would just catch a hint of red it would flicker so fast, every now and then. My car started to smoke underneath my hood, so I went to go get the transmission checked out. Come to find out, I had almost no motor oil. Ugh.
Old Dec 18, 2007 | 06:37 AM
Default Re: (shadha)
Shouldnt the oil light have come on?
Old Dec 18, 2007 | 09:04 AM
roller3804's Avatar
It seems like it only comes on when the car is up to full operation temperature. My oil level is right below the top dot so It couldn't be that thankfully.
Anyone else?
Old Dec 19, 2007 | 12:22 PM
roller3804's Avatar
bump.
has not come on today at all. Came on yesterday three times.
This is weird.
Old Dec 19, 2007 | 02:58 PM
Scrim12's Avatar
Default Re: Check Engine Light comes on randomly? (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Bump for curiosity, my SRS light has done the same thing before.</TD></TR></TABLE>
I'm with Acid on this one, my SRS light tends to do it's own thing sometimes.
Old Dec 19, 2007 | 03:00 PM
roller3804's Avatar
I am talking about the CEL. Check Engine Light.
the SRS light is what flashes when you pull a code.
Old Dec 19, 2007 | 03:17 PM
Default Re: (roller3804)
Me too. Ive had my ecu cleared of all codes, then the cel would come on and my ABS light would blink instead. (sorry about saying it was the srs)
Old Dec 20, 2007 | 04:33 AM
JDMgareth's Avatar
Default Re: (Acidcrakker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker &raquo;</TD></TR><TR><TD CLASS="quote">Me too. Ive had my ecu cleared of all codes, then the cel would come on and my ABS light would blink instead. (sorry about saying it was the srs)</TD></TR></TABLE>
same here. I removed the abs light-
Old Dec 20, 2007 | 01:43 PM
94vtirozguy's Avatar
the cu stores the codes... so do the code checking procedure and this will point you in the right direction
jnb0111
Jan 1, 2016 09:29 PM
Hektik Photography
Oct 1, 2009 07:34 PM
fuzzymemoforshow
Honda Civic (2006 - 2015)
Oct 21, 2006 08:04 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
alb_accord
Mar 30, 2004 06:10 PM
