Yet again
Old Dec 6, 2007 | 01:12 PM
95silverluder's Avatar
Default Yet again
Its still doing it, car is bogging down after about 10 minutes of driving. It does
10x worse after I drive my car for about 30 miles straight, and it gets worse at
night when I have my lights on. I don't know if its the fact that i'm shifting a an
RPM thats too low or what, but I see my friends shifting at way lower than I am
they dont have a problem so I know somethings not right. Any help would be great, thanks in advance.
P.S. Car is completely stock
Old Dec 6, 2007 | 01:24 PM
Acidcrakker's Avatar
Default Re: Yet again (95silverluder)
Clogged Fuel Filter. Dirty spark Plugs? This is hard to diagnos. Are you throwing codes
Old Dec 6, 2007 | 01:27 PM
Default Re: Yet again (Acidcrakker)
no my light isnt on and i checked my plugs the other day, there was a little bit of a black coating, but not huge
Old Dec 6, 2007 | 01:31 PM
mattsnooz's Avatar
Any recent service or anything else you can say? For all we know your talking about a ballon ride gone bad (JK, but we need more info.)
When did this start?
Any conditions (weather/damp/snowing/raining/Cold/Hot/ etc.)??
Any patterns of these conditions?
You say it bogs after your car is warmed up?
So heat, and perhaps load has something to do with it.
Any other conditions? bad idle, hard starts, funny smells, missfires, ticking ...
Old Dec 6, 2007 | 01:32 PM
mattsnooz's Avatar
check cel anyway. Not all codes come up on check engine light!
Old Dec 6, 2007 | 01:35 PM
Default Re: Yet again (mattsnooz)
it has a bad idle, it kind of shakes the car everyonce an awhile along with alittle studder i guess you could call it
Old Dec 6, 2007 | 01:36 PM
mattsnooz's Avatar
could a studder be missfire? like a burp almost?
Old Dec 6, 2007 | 01:37 PM
yep a burp, lol my cars had a beer or two.
Old Dec 6, 2007 | 01:43 PM
and i've tried to check my CEL codes before, but I guess im just an idiot and didnt do it right. I've searched but I cant find how to do it.
Old Dec 6, 2007 | 01:47 PM
To check your cell....
There is a little blue plug behind you radio somewhere. It only has to wires to it; and all you do is connect the two wires togther. Some people use a paper clip, I use a spring from a pen to check the cell. If you connect it and the cel light blinks then you did it right. If you did it right and you dont have the cel light blink then you have no poblems
Old Dec 6, 2007 | 01:50 PM
mattsnooz's Avatar
sitting in your driver seat by your right foot (gas pedal) is where you center counsol ends.
center counsolplastic moulding covers shifter/ebrake/armrest etc.)
Burried in there is a blue plastic two pin quick connector. Stick your hand in behind center counsol by gas pedal. Dig carefully, don't do a homer simpson, and get a zap.
When you find connector jumper it with paper clip (jumper means connect one side to other with something conductive). Then turn your accessories on (don't crank motor, just turn it to point where lights and radio can function.)
Than watch your check engine light flash and count the pulses.
mattsnooz's Avatar
DAMN YOU,
made me type all that out and u sum it up in a paragraph lol
Oh, and for the missfires, I think maybe your timing could be off, or one or multiple cylinders has missfires. Probably one if you only hear one burp. If it double burps, right beside one another, than it could be two cylinders (I've read, ...not sure if thats true or not)
Could be multiple problems too
Old Dec 6, 2007 | 02:04 PM
alright i tried it but nothing came on, i also might add that ive never seen my CEL light. Isnt it suppose to come on when you start up the car?
Old Dec 6, 2007 | 02:08 PM
mattsnooz's Avatar
Yes,.. it is suppose to come on I thought. I think hat indicates you have a faulty ecu, or lights blown...but I highly doubt the light is just blown.
anyway i can like reset my ecu?
Old Dec 6, 2007 | 02:12 PM
mattsnooz's Avatar
yeah, pull negative battery cable off battery. Leave off for a while. I'm not sure, maybe 10 minutes, than plug it in.
I hear you can pull clock fuse/radio fuse too to reset ecu but I'm not sure of that either.
Start with batter cable though please.
Old Dec 6, 2007 | 02:13 PM
alright will do. get back with you for result
Old Dec 6, 2007 | 03:59 PM
AndyD's Avatar
How old is your alternator? Maybe take it to a shop to have it tested.
Old Dec 6, 2007 | 05:34 PM
mattsnooz's Avatar
Default Re: Yet again (AndyD)
ya know what, that crossed my mind too... (alternator) Sounds similar to my first preludes issue, and I swapped in a junk yard alt, and problem vanished.
Old Dec 7, 2007 | 03:35 AM
BlackCatt's Avatar
I had a similar problem years ago, and it was the alternator, so i would definately get it checked man. goodluck
Old Dec 7, 2007 | 05:03 AM
Wahhaahahahhaahaahaha!!!!!!!!!!<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattsnooz &raquo;</TD></TR><TR><TD CLASS="quote">DAMN YOU,
Cheers
Old Dec 7, 2007 | 01:24 PM
so i can just go to a junkyard and get another alternator, and problem might be fixed?
Old Dec 7, 2007 | 01:36 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95silverluder &raquo;</TD></TR><TR><TD CLASS="quote">so i can just go to a junkyard and get another alternator, and problem might be fixed?</TD></TR></TABLE>
Maybe first take it to an AutoZone or Pepboys and have them test it.
If you need a replacement alternator, get a rebuilt one.
HaTa
Mar 27, 2006 03:22 PM
Project_Civic
Apr 3, 2005 05:07 PM
Hapa88
Apr 23, 2003 10:45 AM
Black_eh2
Honda S2000
Apr 12, 2003 07:39 PM
RustyDX
Feb 25, 2003 07:13 PM
