speed sensor problem.. help please
Old Dec 4, 2007 | 11:52 AM
royalfelix's Avatar
Default speed sensor problem.. help please
hey a while back my mph wherent reading nore my miles on the car nor my tripometer. from what i know its the speed sensor that was missed up. so i whent to the junk yard and changed it. and it didnt work nothing. nither of the 3 componets. so i said well maybe it was my bad luck. so i whent again exchanged it and still it doesnt work. what else can it be? and the item im talking about is the sensor with the little metal part along with the "key". hey by any chance will a speed sensor from a honda civic 4 door a 94 or something work on my car? to see if its just REALLY bad luck. please if you know anything on this post ASAP! thanks.
Old Dec 4, 2007 | 12:18 PM
mgags7's Avatar
The VSS goes into the differential housing, which is more towards the firewall, on the transmission. It is almost directly underneath the throttle body.
It is long and slender, has a connector on top, two hose nipples sticking out about an inch, and a shaft with a gear on it at the bottom.
Are we talking about the same thing?
Old Dec 4, 2007 | 12:23 PM
royalfelix's Avatar
yes that speed sensor for the 92 honda prelude h23a1 automatic. besides the plug that comes out and in easy you know what ill show a pic from ebay of what im talking about.
http://cgi.ebay.com/HONDA-PREL...wItem
Old Dec 4, 2007 | 12:25 PM
mattsnooz's Avatar
Default Re: (royalfelix)
hey mgags, don't they all share a similar ground? If its not the vss, maybe its a ground to his tach/speedo/trip
Old Dec 4, 2007 | 12:43 PM
mgags7's Avatar
I'm not sure on the grounding issue, but it sounds, to me, like he has a strictly vss issue.
felix, don't disassemble the thing next time, just get the entire unit. You probably put it together wrong.
Old Dec 4, 2007 | 05:22 PM
royalfelix's Avatar
what are you talking about it has 2 screws that you take out and then u take out the part i showed you from ebay this happend before and i fixed it this way but this time i dont know what happend that it didnt work... so besides that sensor what do you think the problem is?
is there anyway to test the sensor to see if its good?
Old Dec 4, 2007 | 06:28 PM
Toe_Knee's Avatar
Default Re: (mattsnooz)
WHere is the ground for that? I think I have the same problem but my speedo works sometimes only. Tach works fine, the rest don't ( Odometer, tripmeter)
Old Dec 6, 2007 | 10:03 AM
charles1's Avatar
Default Re: speed sensor problem.. help please (royalfelix)
hey man i had that same propblem for about a year. i ended up solving it by taking the gear and its housing out of the top of the tranny and seeing that the arm that held it in place was actually broken. my speedo worked off and on and my cruise control as well as my odometer would only work when my speedo did. so i would pull it out and check to see if that arm is still in one piece. i was lucky and found a whole setup on ebay for 25 bucks. it was used but works perfectly.
Old Dec 6, 2007 | 05:15 PM
royalfelix's Avatar
so besides the sensor and the little peace with the key is not the only problem? there is that whole gear thing? how hard is it to remove that? the one with 2 nipples and what not.
Old Dec 7, 2007 | 02:57 PM
royalfelix's Avatar
bump
Old Dec 9, 2007 | 01:33 PM
royalfelix's Avatar
well i tested the speedsensor off a 94 civic LX it worked but uhh all crazy so i know its the sensor not the gearshaft. thank god. freaking junkyard sold me 2 bad sensors. lol gotta go back tuesday and get a new one.
Old Dec 9, 2007 | 01:37 PM
Hawkze_2.3's Avatar
Inspect the wiring connectors before you blame the sensors...the way that plug for the VSS sits it just retains water and it makes those pins corrode pretty easily.
Old Dec 10, 2007 | 11:45 AM
royalfelix's Avatar
zZzZzZz it was the key i was using for the damn things. the one i had (sensor) was missed up but when i got the sensor from the junkyard it came with its own key. and today i whent back for the 3rd one and saw that it didnt get fixed so i was like no freaking way... and i took a look at the key and saw that my old one had both lips big and the one they had gave me had a big and slightly smaller lip. so with that said i installed the old key with new sensor and my gauges now work again!!!
Old Dec 10, 2007 | 12:29 PM
mgags7's Avatar
This is why I said to not disassemble them....it would have saved you a lot of hassle.
blaze.1
Sep 10, 2009 06:24 AM
y2kferari
10
Aug 19, 2009 11:13 AM
thannon2
Jan 16, 2009 01:59 PM
9hatchman4
Aug 10, 2004 09:02 PM
