sagging
Old Dec 9, 2007 | 03:24 PM
94vtirozguy's Avatar
Default sagging
ok after changing my front wheel bearings i noticed that at the front of the car, one side is higher than the other by 15mm (the rear is fine).
I have koni and eibach's pro kit. I am pretty sure that the eibach's are starting to sag on one side.
Is there any adjustability that i don't know about that would cause one side of the front to be lower than the other ?
Old Dec 9, 2007 | 03:29 PM
Hawkze_2.3's Avatar
Default Re: sagging (94vtirozguy)
Unless some part is bent or damaged, the only way you could be lower or higher on one side is the shock/spring combo. I suppose your camber could be off making it look like the tire is higher or lower on one side, or you could have different tires....
Old Dec 9, 2007 | 03:33 PM
Default Re: sagging (Hawkze_2.3)
yeah i checked the shocks are koni and they are both sitting on the same perch. Also same tyres.
one side i can get one finger between tyre and guard, and the other side i can get two fingers between tyre and guard...
nothing looks bent.
Old Dec 9, 2007 | 03:35 PM
Hawkze_2.3's Avatar
Try measuring from the center of the wheel up to the fender arch and also from the ground up to the fender arch and compare both sides...that might give you some helpfull info.
Old Dec 9, 2007 | 03:36 PM
cool will do tonight.
Old Dec 9, 2007 | 03:37 PM
SnlpeR's Avatar
every suspension peice i put on the prelude always left me with one side higher too
with my current set..i just adjusted the height on the higher side down to match the height on the opposite side
Old Dec 10, 2007 | 12:31 PM
the ground to middle of wheel is the both on the same sides.
height from the middle of the wheel to the guard is where the difference is.
DC2-ProdUcTiOnS
Jun 3, 2009 10:42 AM
RGoose18
Suspension & Brakes
May 5, 2006 10:15 AM
rexwreckjr
Oct 22, 2005 07:19 PM
Understeer
Suspension & Brakes
Jun 24, 2005 08:06 PM
gsr_to_the_MAX
Jan 31, 2005 05:06 PM
