lude wont start
Old Feb 10, 2009 | 10:39 PM
h22lude317's Avatar
Default lude wont start
when i try to start the car it doesnt kick over it just kills the battery
recently i have taken the mounting bolts off the dizzy and moved it around i guess you would call it.
i changed my fuel filter
im pretty sure im getting fuel cause i loosen the banjo bolt on the fuel rail and it got soaked
i replaced the dizzy cap and rotor today
is there a certain way the rotor is supposed to be installed?
i tried to check for spark tonight i got none i dont know if i did it right
i took the wire off the the spark plug and put it to something metal and then i had someone crank the car i saw no spark
i also took the wire off the dizzy and put that to something metal also
i was confused so i tried both
still no spark
the car last started sunday night
if anyone has any input i would appreciate it
Old Feb 11, 2009 | 03:15 AM
BlUAc's Avatar
Default Re: lude wont start
to check for spark i take out the spark plug connected to the wire an leave it on the valve cover then crank the motor... dont no how safe that is though. also stick a long screw driver in the wire an leave it on the valve cover that works to
Old Feb 11, 2009 | 07:40 AM
preluderemis's Avatar
that's what i usualy do also...just take a spark plug out with the wire and crank it to c if it's spark...if your getting spark there u should be fine...if your not getting spark to your spark plug the problem might also be with your main relay (known for going bad on ludes)
Old Feb 11, 2009 | 09:09 PM
h22lude317's Avatar
alright could it not be starting cause of a bad ground?
the batter terminal cables that mount to the motor and tranny are frayed
could this be limiting my voltage to the motor
my el lights dim when i turn something on all the time
Old Feb 12, 2009 | 03:38 AM
mattsnooz's Avatar
yeah, thats probably it. Any bad grounds will give you problems. Ground is pretty much the return side to your battery in low voltage aplications.
The ground to your tranny is an important ground. Rerun the wire in a similar guage wire and see if this clears it up.
So your car is cranking though? just won't actually run/idle?
Most of the time to check for spark you'll have to stick something metal down the boot to touch the contact point in your spark plug wires. I would shove something down the hole, tape it in posistion to your boot to insure good contact. That metal object than you hold it away from your bock or anything considered ground and have a friend crank your car. Remove metal object, put boot back on spark plug. Repeat this step for all 4 cylinders and see if any or all have spark. ONly should crank it 3 times or so and you should see spark. Try doing it in a darker area so you can see the spark. Sometimes its hard to see in regular light.
Old Feb 12, 2009 | 04:35 AM
h22lude317's Avatar
it kicked over and i heard the exhaust so i believe i have spark i will double check though.
getting ground wires today
Old Feb 12, 2009 | 05:40 AM
that can also be it...do you hear clicking when you turn the key??
Old Feb 12, 2009 | 06:04 AM
h22lude317's Avatar
yeah when the battery isnt dead
thats the starter right?
Old Feb 12, 2009 | 06:27 AM
no thats a bad ground...well in my experiences anyways...
Old Feb 12, 2009 | 07:23 AM
h22lude317's Avatar
think i should replace those battery cables
Old Feb 12, 2009 | 02:22 PM
h22lude317's Avatar
i brought my battery to autozone and it was dead 1. some volts
they gave me a new battery and i bought terminal cables
im putting them on tomorrow
Old Feb 12, 2009 | 03:03 PM
well in my cases the batteries where always fine...just the cables got rusted up scince they spread salt on the roads here like the roads are pretzels...so changing the battery and cables will definitly help
Old Feb 12, 2009 | 03:42 PM
h22lude317's Avatar
true man im swapping those cables out tomorrow
ill let you know if you want me to
Old Feb 13, 2009 | 05:56 AM
yeah let me know
Old Feb 16, 2009 | 06:33 PM
h22lude317's Avatar
so i put the new battery cables on and all and it cranks but wont start
i think cause it only kicked over once that i need new spark plugs
mine are all black on the tips and ****
Old Feb 16, 2009 | 06:40 PM
well atlease its cranking...try dipping them in gas (i have to do that with my EF evrytime i want it to start because the Orings are shot )...either that or just swap out the spark plugs...however dipping them in gas should make the car start
Old Feb 16, 2009 | 07:09 PM
lude1888's Avatar
It sounds like a definite short.
h22lude317's Avatar
true ill try that tomorrow thanks
Old Feb 17, 2009 | 10:16 AM
h22lude317's Avatar
okay today i cleaned the spark plugs
it kicked over 2 or 3times
everytime it kicked over it bogged down and died immediately
trying to get new spark plugs tonight
keep in mind i have a iat sensor cel
Old Feb 18, 2009 | 11:03 AM
h22lude317's Avatar
starts runs now i gotta get that sensor
white smoke poured out when i started it so after a minute i turned it off
Cameron60
Feb 19, 2009 10:22 PM
mr_fobster
Nov 13, 2008 09:10 PM
Tad
Sep 5, 2007 09:51 PM
GoldCoin
Aug 21, 2006 06:29 PM
prelude1897
Mar 27, 2006 01:38 PM
