Distributor question!!
Old Feb 1, 2009 | 12:09 AM
meanshyguy's Avatar
Default Distributor question!!
So I'm almost done with my build, it's an H23vtec and I was wondering if an H22 distributor will be compatible? I don't have the one that came originally with the car (H23) Are the OBDII connectors different on the H22 dizzy and not compatible with the H23 wire harness?
Old Feb 1, 2009 | 12:47 AM
lunatics209's Avatar
Default Re: Distributor question!!
h23 vtec.?? aren't you using the h22 head?
Old Feb 1, 2009 | 07:07 AM
98vtec's Avatar
moderator emeritus
obd1 h22 and h23 distributors are the same. Just make sure you get the right one for if you are internal or external coil. Either way, but can be modified very easily to work with either.
Old Feb 1, 2009 | 01:55 PM
meanshyguy's Avatar
Yes I'm using the H22 head from a 97 prelude, so they also sent me the dizzy, I don't have the one that came with my car anymore, I have a 93 si.
I've already heard both distributors are the same, it's just that I wanted to know if I would have to modify the H23 wiring for the obdII dizzy or just order an obdI? Are the connectors the same?
Old Feb 1, 2009 | 06:42 PM
meanshyguy's Avatar
Anyone has an answer to this? I really need to know so I can order an obd1 dizzy if I have to!!
Old Feb 2, 2009 | 05:49 PM
slamdlude's Avatar
If your car and harness are OBD1, you need an OBD1 distributor. 93 is OBD1 so I would have to say that you need an OBD1 distributor. The wiring is different for OBD1 and OBD2. Your harness will not plug into the OBD2 distributor. Even if it would it would not work properly. You can use the H23 or the H22 distributor as long as it is for an OBD1 engine.
Timmay
Apr 14, 2009 10:49 AM
h22_crx
Jan 18, 2007 05:53 PM
Zer0skll
Dec 21, 2006 11:53 AM
ZigenBallz
May 3, 2004 10:08 AM
