Flexpipe & Bushings
Old Feb 5, 2009 | 09:36 AM
NineT1Lude's Avatar
Banned
Default Flexpipe & Bushings
where can i find a flexpipe cupler???
and rear lower control arm bushings...?
thanks
Old Feb 5, 2009 | 10:58 AM
Kronn 98SH's Avatar
Default Re: Flexpipe & Bushings
A flexpipe can be found lots of places, ie your local muffler shop, eBay, etc. Others might disagree but I really can't see myself paying up to $50 for an almost functionless piece of metal. That's why I got my 2.5" ID flexpipe from eBay for about $8.
Old Feb 5, 2009 | 12:47 PM
NineT1Lude's Avatar
Banned
i just need the cupler. there's a leak in between the pipe and the flexpipe.
Old Feb 5, 2009 | 12:50 PM
NineT1Lude's Avatar
Banned
what about the control arm bushings? i've looked on ebay and nothing-
Old Feb 5, 2009 | 02:39 PM
Kronn 98SH's Avatar
You have an actual coupler on your exhaust instead of it being welded? Or do you mean the flange?
Old Feb 5, 2009 | 06:01 PM
NineT1Lude's Avatar
Banned
coupler, not welded
Old Feb 5, 2009 | 06:46 PM
Kronn 98SH's Avatar
you should take a picture of this "coupler"
Old Feb 6, 2009 | 01:48 AM
MikeLuder's Avatar
Just get a real header with a new flex pipe, and or, have it cut out completely and run a straight pipe thru it.
As for the control bushings, try Energy Suspension polyurethane bushings, or Advance Auto Parts sells upper & lower control arm bushings by a Japanese brand called Moog that is good.
Old Feb 6, 2009 | 08:33 AM
NineT1Lude's Avatar
Banned
i've looked for those bushings at every auto parts store in the area and they only have the front ones. i guess i'm out of luck.
Old Feb 6, 2009 | 08:51 AM
NineT1Lude's Avatar
Banned
this is where it's leaking....
Old Feb 6, 2009 | 09:31 AM
Kronn 98SH's Avatar
Your arrow points to the spot where the flex pipe is WELDED to the collector. If that's where you're leaking, you just need to take it to a local muffler shop and get it re-torched. If you're leaking where the actual mesh portion first touches the solid metal, that's still part of the flex pipe. Best bet is to replace the flex pipe for, like I said, $8 + S/H. Here's an example:
http://cgi.ebay.com/ebaymotors/Parts...1%7C240%3A1318
Old Feb 6, 2009 | 09:35 AM
NineT1Lude's Avatar
Banned
where?
94EG8
Honda CR-V & Element
Jul 13, 2013 01:10 PM
JDM215
Suspension & Brakes
Nov 3, 2010 10:56 PM
theineffable
Honda Civic (2001 - 2005)
Oct 12, 2010 04:12 PM
Jaydeep
Aug 10, 2010 04:21 PM
AccordEX1991
19
Apr 14, 2008 11:35 AM
