H22 Ignition problems..
Old Jan 31, 2009 | 02:20 PM
theme's Avatar
Default H22 Ignition problems..
My buddy has a 1993 prelude with a h22 vtec.. had msd box and coil and someone stole the msd box and coil and distributor.. im just curious what wiring goes to the external coil so I can wire it up, also can I use a h23 distributor?? anyway, any advice would be appreciated.. asap also.. thanks guys...
Old Jan 31, 2009 | 07:22 PM
Peeonu25's Avatar
Default Re: H22 Ignition problems..
eh that sucks...
h22 and h23 use the same dizzy, thats what im running. make sure you get the right plug if its obd1 or obd2, making a conversion harness is easy, but its one more step.
"According to the diagram that I have it shows that there is a Blk/Yell and Yell and a Blue wire to the external coil. You will connect the MSD as follows, take the Blk/Yell and the Yel and remove from the coil, then connect to the small red of the MSD Unit. Take the Blue of the coil and connect to the white of the MSD Unit. This will leave no wires on the coil at this point. Then from the MSD Unit you will take the orange and connect to the coil positive terminal, which is where the Blk/Yel was originally connected. Then take the Black of the MSD Unit and connect to the terminal on the coil where the blue was connected. These will be the only 2 wires on the coil. The only 2 wires left will be the heavy red and heavy black to battery."
Old Jan 31, 2009 | 08:01 PM
theme's Avatar
ok but i dont have any of that i wanna put it back to stock so which goes where to a stock coil?.. i appreciate the help
Old Jan 31, 2009 | 08:36 PM
Peeonu25's Avatar
is it an h22a or is it a USDM H22? JDM use an internal coil and the USDM use a external
best bet is to go buy a manual for the car, i run a MSD coil with my h22a so i converted from internal to external. sorry.
Old Jan 31, 2009 | 08:38 PM
Peeonu25's Avatar
all i know is the stock external coil bracket is right behind the dizzy if you were looking at the car from the front.
Old Feb 1, 2009 | 07:04 PM
meanshyguy's Avatar
Same question here, can the connectors for OBD1 dizzy be ordered separately? Or how's the conversion process??
Old Feb 2, 2009 | 10:33 AM
SKDRCR's Avatar
https://honda-tech.com/zerothread/2275163
Old Feb 2, 2009 | 11:20 PM
Peeonu25's Avatar
Originally Posted by SKDRCR
invalid thread...
just go to the wrecking yard find an obd2 honda and obd1 honda... grab the right male and female plugs... follow the wires... connect them... done.
rfslapshot1
Oct 16, 2011 06:54 PM
captaindammit
Jun 4, 2008 04:00 PM
civicstar
Aug 31, 2005 02:18 PM
darockjc
Sep 30, 2004 10:35 AM
crazykid
Apr 29, 2004 06:13 PM
