bad fuel pump?
Old Jan 31, 2009 | 05:38 PM
ALTERED4's Avatar
Default bad fuel pump?
usually when the fuel pump doesnt prime in our cars, the culprit is a bad main relay or a bad ground, right??? well i tried to run the car this morning, and it would not start (i drive the car every monthor so, just to shake the cobwebs loose)... when i turn the key the engine cranks, but no pump priming and no fuel pressure (i've got a gauge)...
the main relay is clicking, and i tested the plug at the pump with a 3 dollar tester. the tester lights up for a couple seconds after turning the key (when the pump should be priming).
apparantly the main relay is working fine. is it possible that my fuel pump went out? anything else it could be?
i know i've probably answered my own question, its just that i don't think i have ever heard of a fuel pump in a prelude go bad...
Old Jan 31, 2009 | 07:12 PM
Peeonu25's Avatar
Default Re: bad fuel pump?
fuel pumps a fuel pump, if its an object other than a solid rock it can break and go bad. I'm more of an accord guy, and they go bad in accords... i just put in a 255ml/s last week... its not a bad job if you have an empty tank...
Old Jan 31, 2009 | 08:43 PM
cdownin's Avatar
can you not switch out the intake pump from the back seat....
Honda'sAreDank
Jun 29, 2012 10:31 AM
JimmyM86
15
Oct 18, 2007 08:44 PM
Unjockable
34
Mar 3, 2004 07:38 AM
-DC2-
Aug 4, 2003 09:58 AM
