Alternator!!
Old Jan 8, 2004 | 03:38 PM
shooitzlinh's Avatar
Default Alternator!!
i buy a prelude motor and it came with out a alternator bracket and all the wires are cut and i need to know what i need to buy for the alternator and what are alternator bushes
Old Jan 8, 2004 | 03:49 PM
goosane's Avatar
Default Re: Alternator!! (shooitzlinh)
hmm...i don't know how much help i can be but you need the bracket to keep belt tension, you can get one in a junkyard or something for cheap. you need to replace all of the wires and make sure you have the ground wire properly connected. if it's an early model and it doesn't have an external voltage regulator, you should try to replace that also. i think bushes are the diodes inside of the alternator, if you don't know how to take it apart and replace them, you're better off buying a new one. someone correct me if i'm wrong, good luck. cya
Old Jan 8, 2004 | 03:53 PM
AndyD's Avatar
If you need an H23 alternator or alternator bracket let me know.
Old Jan 8, 2004 | 04:03 PM
Bigjussin's Avatar
Default Re: Alternator!! (AndyD)
u will be able to use andyd's alt and bracket.....or salvage one out...u can also use one off a 92-96 camry 4cyl...its the same NipponDenso alternator
