Idle issues, please help!
Old Jan 8, 2004 | 02:21 PM
fast4w$'s Avatar
Default Idle issues, please help!
When my car is fully warmed the idle goes nuts, bouncing from 0-2000 rpms. I'm getting pretty sick of it. I replaced the idle sensor on the intake mani and I still have this problem. My buddy who owns a shop said hes seen similar issues with H22/H23 ludes and he told me the problem was the sensor on the throttle body and that the whole tb needed to be replaced cuz the sensor is riveted on. This seems alittle weird. Turns out I know one of the guys who my "buddy" was talking about and called him. He said my "buddy" was full of **** cuz he took the car somewhere else and had them completely clean out the tb with BG air intake cleaner (designed for TB's and IM) and the car has been fine since....Any ideas??? My can of BG is on the way.
Old Jan 8, 2004 | 02:26 PM
vet_girl's Avatar
Default Re: Idle issues, please help! (FaS4wS)
It can definitely be a cause of a dirty TB, but check for vacuum leaks as well, and check if your idle screw is loose.
Old Jan 8, 2004 | 02:30 PM
str8rcn's Avatar
Default Re: Idle issues, please help! (vet_girl)
Also check your coolant level.If the coolant system has a air pocket in it it will cause the idle bounce.
Old Jan 8, 2004 | 03:19 PM
Slatelude's Avatar
Default Re: Idle issues, please help! (str8rcn)
make sure for no vaccum leaks/clogs, I know if the FPR hose is disconnected it causes that exact problem sometimes.
Old Jan 8, 2004 | 05:38 PM
specalk's Avatar
clean out your idle air control valve and the fast air idle valve, theres coolant lines that run threw both valves and sometimes they get block up over time, mine was completely blocked and my car did the same thing,, all you to is take a needle and some throttle body cleaner and pick up the gunk and spray it.. Id also spray the intake manafold and throttle body
Old Jan 8, 2004 | 08:00 PM
92HPSI4WS's Avatar
having the same prob..
http://www.superhonda.com/foru...43068
Old Jan 9, 2004 | 03:41 AM
fast4w$'s Avatar
Default Re: (specalk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by specalk &raquo;</TD></TR><TR><TD CLASS="quote">clean out your idle air control valve and the fast air idle valve, theres coolant lines that run threw both valves and sometimes they get block up over time, mine was completely blocked and my car did the same thing,, all you to is take a needle and some throttle body cleaner and pick up the gunk and spray it.. Id also spray the intake manafold and throttle body</TD></TR></TABLE>
Thanks for the help, I will attempt to do this tomorrow...my only problem is i'm not sure which is which. I'm pretty sure the idle air control valve is the one on the intake mani that i just replaced, so that piece is new. I will clean the coolant lines that run in and out of it.
Where is the fast air idle valve?
Old Jan 9, 2004 | 06:20 AM
AndyD's Avatar
My car did EXACTLY what you are saying when I drained out all the coolant. The car would idle fine for a few minutes and then when it got to operating temp...the rpms would jump from 750-2000 every two seconds.
As soon as I filled up the radiator....it went away.
Old Jan 9, 2004 | 09:09 AM
fast4w$'s Avatar
Default Re: Idle issues, please help! (AndyD)
Thanks for the info guys i will let you know how things turn out. I'm still not sure where my fast idle valve is...anyone? I'm also gonna flush the cooling system
Old Jan 9, 2004 | 10:04 AM
pentaq's Avatar
under TB. there is coolant pipe going there
RudeLudeHatch
Dec 14, 2008 06:47 PM
ericstambaugh07
Jan 20, 2007 01:52 AM
tico
10
Aug 7, 2006 10:37 PM
OneFastGsr
Oct 8, 2003 08:30 AM
Kamin
Jan 12, 2002 08:43 AM
