h22 head bolt torque specs
Old 01-13-2004, 05:25 AM
tuan...'s Avatar
Default h22 head bolt torque specs
im in the process of reinstallin my head and i need some specs... i wanst sure if all honda motors have the same torque specs for the head bolts or not. i also need torques specs for camshaft bearing cap bolts, camshaft holder bolts and cam gear torque specs. thanks alot
Old 01-13-2004, 06:32 AM
Revi's Avatar
Default Re: h22 head bolt torque specs (h22poweredgsr)
Tighten the head bolts in 3 steps, with the last step being at 72.3 Ft/Lbs, in this order to prevent warpage:
9 – 5 – 1 – 3 – 7
8 – 4 – 2 – 6 – 10
1st step: 29 ft/lbs
2nd step: 51 ft/lbs
3rd step: 72.3 ft/lbs
Camgear bolts : 37 ft/lbs
Camshaft holder bolts : 8.7 ft/lbs (Not the camshaft plates)
Couldn’t find the camshaft bearing bolts.
Hope this helps a little bit.
Old 01-13-2004, 07:28 AM
tuan...'s Avatar
yea that helps alot, thanks
Old 01-13-2004, 09:52 AM
LudeyKrus's Avatar
There was a thread on here not too long ago....it showed that torquing down the camshafts is NOT that easy....def. need to look at that.
EDIT - Here's a pic for the cams:
Old 01-13-2004, 10:49 AM
Revi's Avatar
Default Re: (LudeyKrus)
Those are the camshaft plates, below those are the actual camshaft holders that hold the camshafts to the head. Those were the ones he was talking about.
Old 01-13-2004, 10:59 AM
117's Avatar
Default Re: (Revi-Ra)
Those are the bolts that hold the cam caps in place. i.e. the bolts for the cam caps and the cam plates, as you're referring to them, are the same, except for the 8 bolts on the outer edge (numbers 21 through 28 in the above diagram).
Old 11-20-2004, 01:37 PM
ludetrouble's Avatar
Default Re: (117)
can't see diagram
CiViCgT32
11-17-2006 07:13 PM
high_revs
06-06-2005 04:34 PM
EGhatch22
01-15-2005 11:06 PM
anothersickhatch
12
06-10-2004 02:26 PM
NOOTRON20
10-11-2003 10:18 AM
Quick Reply: h22 head bolt torque specs
