help me quick
Old Jan 7, 2004 | 12:23 PM
machinehead's Avatar
Default help me quick
im locked out of my car with the engine running. how do i turn the engine off from outside the car, the hood is up. can i just pull the cap wire?
Old Jan 7, 2004 | 12:28 PM
CHK4TIX's Avatar
Default Re: help me quick (machinehead)
yes, you can just dont get shocked
Fly1865's Avatar
battery, neg side. I don't see how that could hurt.
Old Jan 7, 2004 | 12:29 PM
Sephro's Avatar
Default Re: help me quick (CHK4TIX)
Pull the battery cable... Or pull the cable from the coil to the distributor.
PrecisionH23a's Avatar
loosen your throttle cable bracket so the plate in the throttle body closes. Don't pull of any plug wires, or you'll probably shock the **** out of yourself.
Sephro's Avatar
Default Re: help me quick (Fly1865)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fly1865 &raquo;</TD></TR><TR><TD CLASS="quote">battery, neg side. I don't see how that could hurt.
Only might need code for radio...
Old Jan 7, 2004 | 12:32 PM
ok done. i tried the whole coat hanger trick, had good position but the wire kept slippin off the power lock switch. i had it on the door handle but it wouldnt unlock when i pulled it. tried getin in the lock thing but that wasnt happening. I even tried hitting the sunroof button so i could climb in. Grrrr.
Old Jan 7, 2004 | 12:33 PM
oh btw, i pulled the cap cable, no shocks.
Old Jan 7, 2004 | 12:35 PM
Thanks guys. now i gotta wait for da locksmith
Old Jan 7, 2004 | 12:38 PM
Sephro's Avatar
Default Re: (machinehead)
AAA... or a garage will be cheaper.
Old Jan 7, 2004 | 12:42 PM
too late hes on his way. oh well
Old Jan 7, 2004 | 01:00 PM
Timmy Joe's Avatar
You need a big baseball bat for those times when you lock your keys in your car.
Old Jan 7, 2004 | 01:15 PM
OTT's Avatar
OTT
No! your accesory power is still on so you just use the coathanger etc. to push the window switch down and your in! dont scratch your paint away.
Old Jan 7, 2004 | 01:18 PM
OTT's Avatar
OTT
Oh, btw. Honda designed it so it was hard to get any type of 'sliping' device down the door frame easily and the edge of the power lock Switch is curved so you cant grip it with a hanger!
I did the same and it wouldnt let me unlock with the alarm b-cos of key immob and engine running! its a pain
Old Jan 7, 2004 | 03:38 PM
UA6 BALLER STATUS's Avatar
If you pour water in your gas tank the car will shut off due to a lack of octane in the enigne
Old Jan 7, 2004 | 06:48 PM
SKDRCR's Avatar
don't you have cops in nj with slim-jims
could have saved yourself some money
Old Jan 7, 2004 | 06:50 PM
PowerUser's Avatar
Default Re: (Type_SH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type_SH &raquo;</TD></TR><TR><TD CLASS="quote">If you pour water in your gas tank the car will shut off due to a lack of octane in the enigne</TD></TR></TABLE>
there are many other ways tou can do it with the hood up.
Old Jan 8, 2004 | 05:03 AM
Jagan'92's Avatar
You need to get a really stiff piece of Straight wire (with a little "L" at the end).
Then you get a Wedge of wood.
you work the wedge up and in, and then pry the window glass outwards to slip the wire down the crack into the car. Then pull up on the door lock switch.
I can't believe I once paid a guy 30$ to do that. Granted he did in 5 minutes what it takes me 10 to do.
Other things I've used: vines instead of wire (when you're in the woods you know), and plastic spatulas instead of the wood. Works great!
Old Jan 8, 2004 | 05:46 AM
OTT's Avatar
OTT
How could you pry a Prelude window open?
Its go a guide rail on the left and sits IN the frame! you have to pull the top of the door away as far as possible; pull the windows and youll smash it!
Old Jan 8, 2004 | 06:04 AM
Jagan'92's Avatar
Default Re: (OTT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OTT &raquo;</TD></TR><TR><TD CLASS="quote">How could you pry a Prelude window open?
Its go a guide rail on the left and sits IN the frame! you have to pull the top of the door away as far as possible; pull the windows and youll smash it!</TD></TR></TABLE>
No. It won't break if you are careful. That guide rail doesn't hold the window in
tight. Force the wedge between it and the guide, then force the wedge up into the guide, then over the top of the window, and then you can pry the window out. A locksmith WILL do exactly this.
Should I draw some pictures of it?
Old Jan 8, 2004 | 06:26 AM
OTT's Avatar
OTT
When mine was locked out at the garage that sprayed it they have their own locksmith cross mechanic. He said that but just couldnt do it, said it was tighter than hes ever seen an he ended up puling the top of the door away from the frame as much as possible (like jsut enough to get the breaking wire down the frame)
Old Jan 8, 2004 | 01:37 PM
boostlee's Avatar
Default Re: (OTT)
your car must be a virgin
Old Jan 8, 2004 | 02:19 PM
SKDRCR's Avatar
Default Re: (boostlee)
you know there is an easier way to unlock it from the outside,
get a wood chip or something and stick it in your belt molding
this will give you room to take a coat hanger and stick it in
near the lock cylinder. a little jolt on the link will cause it to unlock
jordy478
Apr 20, 2015 12:50 PM
Metal Head
Audio / Security / Video
Mar 15, 2009 07:21 AM
simonEp3
Jul 14, 2008 04:49 PM
jok
Aug 25, 2004 08:06 PM
crxaddikt
Dec 16, 2002 03:25 PM
