Checking engine light after long time....posible?
Old Jan 13, 2004 | 01:15 PM
Revi's Avatar
Default Checking engine light after long time....posible?
A while back, i want to say maybe 4 months ago, i had my check engine light come on. After i saw this, i turned of the car, pulled the key out, and then started the car again and the light was gone. Along with the engine light was the ATTS light. So i figured it was the atts thowing a signal and left it at that. The car never ran different so i just ignored it. But i heard that when the check engine light comes on the atts light will come on also. Regardless if there was something wrong with the atts unit or not.
Anyways, bottom line is ive become extremely curious at what caused the light to come on. Can i still check the ecu and get a read out of what cell it through even though its been so long? Also, how do you check it.
Old Jan 13, 2004 | 01:19 PM
Behan's Avatar
Default Re: Checking engine light after long time....posible? (Revi-Ra)
after 50 or so starts it will be erased from the ecus memory. But it won't hurt to try.
Not sure if its the same on the 5th gen but on the 4th gen there is a plug underneath the radio that you jump to display the codes.
Old Jan 13, 2004 | 01:20 PM
sharkcohen's Avatar
You could check and see if a code is stored.
http://www.hondaprelude.to/art....html
Old Jan 13, 2004 | 01:36 PM
Revi's Avatar
Default Re: Checking engine light after long time....posible? (sharkcohen)
Well went out and did it, but it was the ATTS light that flashed, NOT the engine light....WTF? Anyways ended up beign 35. Lets look at the helms.....
Old Jan 13, 2004 | 01:58 PM
Revi's Avatar
Well turns out to be that 35 is Reference Voltage. Im gonna have to check the wiring on the ECU and ATTS CU, and since i have a VAFC installed, its problably a wire problem.
Old Jan 13, 2004 | 07:27 PM
01prelude's Avatar
I have a 5th gen and my check engine light came on and I contacted Honda cause it was still under warrant. The guy told me that if you don't screw on your gas cap at least 3 times when you close it that could happen..
rccnh
Mar 12, 2007 01:29 PM
pens81
Acura TSX
Mar 30, 2006 03:42 AM
jdium
Mar 4, 2006 10:13 PM
ZeroGSR
Oct 7, 2004 04:57 AM
Preludegirl
Dec 3, 2003 08:14 AM
