GM Syncromesh question
Old Jan 7, 2004 | 07:37 PM
PreludePhill's Avatar
Default GM Syncromesh question
when i go to buy it should i just as for the GM syncromech Friction Modified or is there a special part #?Thanks
Old Jan 7, 2004 | 07:49 PM
Matgallis's Avatar
Default Re: GM Syncromesh question (N2oH22)
just go to a General motors deal and ask for gm syncromesh.
Old Jan 7, 2004 | 08:31 PM
NoLipRacen's Avatar
Default Re: GM Syncromesh question (92`Legend)
YES! get the friction modified, the regular gm synchromesh is just a regular tranny fluid. its the friction modified one that everyone talks about
p.s. thats what il be putting in my tranny when i change it out
Old Jan 7, 2004 | 08:53 PM
PhatboyNYC's Avatar
I used regular GM Synchromesh and it works fine for me. Do a search on the subject. There seems to differing opinions regarding the use of the friction modified and regular one.
Old Jan 8, 2004 | 12:24 AM
Gerhard_001's Avatar
Yes the info that you get will differ greatly, People swear by both. Just search if all else fails get both and see which one fits your needs.
Old Jan 8, 2004 | 12:42 AM
Luchini's Avatar
Default Re: GM Syncromesh question (Gerhard_001)
I called in and they asked me what car it was for. I said Honda Prelude and he told me wrong dealership. What do i do now?
Old Jan 8, 2004 | 01:30 AM
fast+forward's Avatar
Default Re: GM Syncromesh question (Luchini)
show up to the parts dept, tell them to give you these parts
"Synchromesh ("round" bottle) - #12345349 OR
Synchromesh Friction Modified ("oil" bottle) - #12377916"
then tell them to suck mr. vienna sausage
Old Jan 8, 2004 | 02:10 AM
Luchini's Avatar
Default Re: GM Syncromesh question (breakaway)
haha... props for the part numbers. how much of each do i need? just 1 of each? its for a 5th gen btw
Old Jan 8, 2004 | 03:33 AM
KENLUDE97's Avatar
2 quarts.
Old Jan 8, 2004 | 07:14 AM
JDMBB2's Avatar
Default Re: GM Syncromesh question (KENLUDE97)
does this really work well. my 3rd gear is horrible scratches like crazy. you think it can be fixed with this
Old Jan 8, 2004 | 09:37 AM
silver97prelude's Avatar
I have heard not to get the friction modified kind.
I just went to a Chevy(GM) dealer and asked them for 2/3 quarts of GM synchromesh in the blue bottle.
It works great, no more 5th gear grind!
Old Jan 8, 2004 | 09:50 AM
SKDRCR's Avatar
Default Re: GM Syncromesh question (silver97prelude)
i have heard that the friction modified mtf will
wear out your seals quicker because of all the additives
so i went with the regular gm synchro
Old Jan 8, 2004 | 09:56 AM
bad-monkey's Avatar
u can buy regular synchromesh @ autozone.
it's a pennzoil product. look for pennzoil synchromesh MTF.
Old Jan 8, 2004 | 10:09 AM
Sephro's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">u can buy regular synchromesh @ autozone.
it's a pennzoil product. look for pennzoil synchromesh MTF.</TD></TR></TABLE>
yeah but be prepared to spend about $5 less a quart
Same exact stuff. Same part numbers and everything!
Old Jan 8, 2004 | 02:12 PM
Exactly.
Old Jan 8, 2004 | 03:07 PM
bad-monkey's Avatar
Default Re: (Gerhard_001)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly.</TD></TR></TABLE>
heh, and i use honda mtf
Old Jan 8, 2004 | 03:27 PM
Matgallis's Avatar
get 3 bottles, it's pretty hard to get it exact the very first try.
Old Jan 8, 2004 | 04:12 PM
plnoldrick's Avatar
synchromesh
Old Jan 8, 2004 | 04:58 PM
Toretto's Avatar
Default Re: (plnoldrick)
I switched to GM syncromech a few months back. If you are having some trouble with gears grinding, give it a try. My 5th gear was starting to act up, and my 2nd gear didnt want to engage quickly at higher RPMS, but after changing to this MTF, problems are gone. If your not having any problems though, stick with the Honda MTF.
Old Jan 8, 2004 | 05:34 PM
specalk's Avatar
Default Re: (Toretto)
i use moble 1 10w 30
Old Jan 8, 2004 | 07:33 PM
racekar's Avatar
i have had the regular synchromesh from the dealer in and after a couple of road racing events its not as smooth. But it still prevents me from grinding 2nd gear. My friend with the friction modified stuff says his is still smooth after several events.
maddheezy
Honda Civic (2006 - 2015)
Sep 28, 2007 11:08 AM
flashmang
Oct 23, 2004 06:06 PM
stealthhatch
Mar 19, 2004 07:54 AM
a1320honda
14
Mar 13, 2004 03:16 PM
HuskerHybrid
May 20, 2003 09:06 AM
