problem with taillights
Old Jan 13, 2004 | 06:06 PM
coldfiremx's Avatar
Default problem with taillights
i have a 92 lude and sterero is gone, it was a theft recovery, but anyways my problem is that the tailights are constantly on when the fuse is in, so i have to pop the hood every time i want my tail lights on, anyone ever had this problem, how to fix it, cause it's a pain in the ***.
thanks
Old Jan 14, 2004 | 03:32 AM
prelude1897's Avatar
Default Re: problem with taillights (coldfiremx)
Some wires may be crossed or there is a short someplace. You should take it to a shop and have them rewire the car
Old Jan 14, 2004 | 03:42 AM
Shakes's Avatar
space cadet
Default Re: problem with taillights (prelude1897)
use a voltmeter and check the ground wires on your lighting system. there should be no voltage there. when you do this make sure that the car is on (or in acc, which ever works)
if you have voltage then you have a ground in contact with one of your power contacts.
also check the HOT to ground connection. using the diode portion of the multimeter read from HOT to ground. if it beeps then you have a short to ground in the power wiring.
if at any point you find something wrong skip a few feet of wire (using the same referance point i.e. same ground or hot point) and move the other lead. continue doing this until you come across a section where you do not have a problem. the rest of that wire will be ok. in the area that you have already checked shorten the leingth of distance between check points until you find it.
HTH
Old Jan 14, 2004 | 05:37 PM
coldfiremx's Avatar
thanks, for the input, but i was just checking to see if anyone else has had this problem
b18c inside
Dec 13, 2011 05:34 PM
jinteg730
Nov 26, 2006 04:04 PM
sireg6
Jul 29, 2006 09:40 PM
tgctruly
Nov 8, 2004 12:12 PM
PoonHunter
May 15, 2003 09:23 PM
