Motor Question?
Old Jan 10, 2004 | 08:34 PM
Coldth1's Avatar
Default Motor Question?
I just bought a 92 prelude s-type .
It has 240k miles and I am looking at new motors. I have been looking at B18's and H22's. My question is wich would give me more bang for my buck. I no the b18 come's with 180hp and the h22 come's with 200hp. I am looking for something fast, and still be able drive it every day. I want to be able to beet those people with V8's that think that just because a car has 4 cylinders its slow. Any help would be nice. Thanks.
Old Jan 10, 2004 | 09:15 PM
WRS Motorsports's Avatar
Default Re: Motor Question? (Coldth1)
H22. Less money, more power and it belongs in the Prelude.
Old Jan 11, 2004 | 08:36 AM
PrecisionH23a's Avatar
A simple h22a swap with minor bolt ons and some weight reduction should put you in around 14.6-14.9 depending on how well of a driver you are. A good rule of thumb is you are about .1 faster on the 1/4 mile per 100lbs lost.
Keep in mind most decent stock v8's run low 14s.
Old Jan 11, 2004 | 08:43 AM
prelude1897's Avatar
Default Re: Motor Question? (GudeH23a)
H22 all the way man....
Old Jan 11, 2004 | 09:48 AM
SKDRCR's Avatar
Default Re: Motor Question? (prelude1897)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelude1897 &raquo;</TD></TR><TR><TD CLASS="quote">H22 all the way man.... </TD></TR></TABLE>
what he said^^^^^^^^^^^
Old Jan 11, 2004 | 10:08 AM
ludeboy555's Avatar
Default Re: Motor Question? (SKDRCR)
prelude is already a bit sluggish w/ the H22, you can only image what a B18 would do. Plus never heard of anyone putting a B18 in a Lude.
Old Jan 11, 2004 | 10:40 AM
UA6 BALLER STATUS's Avatar
nothing less than the H22
H DUCE DUCE is the way to go
Old Jan 11, 2004 | 10:55 AM
SKDRCR's Avatar
Default Re: (Type_SH)
looks like a nice paint job though for 240k
Old Jan 11, 2004 | 11:43 AM
stinger's Avatar
H22 all the way
Old Jan 11, 2004 | 02:34 PM
CHK4TIX's Avatar
Default Re: (stinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinger &raquo;</TD></TR><TR><TD CLASS="quote">H22 all the way</TD></TR></TABLE>
Old Jan 11, 2004 | 02:48 PM
H22A EG6's Avatar
Default Re: (CHK4TIX)
why would you even put a B series motor in a lude. unless it is an older lude that came with a b20. i think?? corect me if i am wrong
Old Jan 11, 2004 | 03:08 PM
DisturbingFactor's Avatar
Default Re: (H22A EG6)
I've seen a b16 in a lude before of course it was in an older lude like H22A EG6 said....it was an 86 prelude. Big difference compared to the stock 86 prelude A20A.
Old Jan 11, 2004 | 04:54 PM
Coldth1's Avatar
Thanks for all the replys looks like i am going for h22. Also would it be better to go to a junk yeard and find one or should i order one online?? If u think i should order one online whats some good site's to order it from? Thanks for all the help.
Old Jan 11, 2004 | 07:46 PM
FalconMan's Avatar
*search*.....many threads on where to get engines
Old Jan 11, 2004 | 08:18 PM
stareatsun's Avatar
If you got a B18C (GSR) it has 170hp and &lt; 150lb/ft torque. An H22 (Prelude VTEC) would put down 190hp and about 160 lb/ft torque. The H22 would roughly go for around $1000-$2000 cheaper for a complete swap JDM or USDM. Also the H22 is about 300 lb heavier and is designed for the Lude. Something to think about.
Old Jan 12, 2004 | 03:00 AM
Gerhard_001's Avatar
Default Re: (stareatsun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stareatsun &raquo;</TD></TR><TR><TD CLASS="quote">If you got a B18C (GSR) it has 170hp and &lt; 150lb/ft torque. An H22 (Prelude VTEC) would put down 190hp and about 160 lb/ft torque. The H22 would roughly go for around $1000-$2000 cheaper for a complete swap JDM or USDM. Also the H22 is about 300 lb heavier and is designed for the Lude. Something to think about.</TD></TR></TABLE>
Where are you getting your specs? B18C1- 128ftlb of torque, B18C5- 132ftlb of torque, no way a b-series can make 150ftlb's of torque stock. The H series motor is 76lbs heavier than a B16, and about 60lbs heavier than the B18C.
Old Jan 12, 2004 | 03:22 AM
dankbudz11357's Avatar
yeah the older preludes did come with the b20. and don't just go with a normal h22 swap. you have a type-s. so personally i think you should go with a h22 type s motor. so then things would be exactly the same with the new motor. just another think to think about.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Coldth1 &raquo;</TD></TR><TR><TD CLASS="quote">I just bought a 92 prelude s-type .
It has 240k miles and I am looking at new motors. I have been looking at B18's and H22's. My question is wich would give me more bang for my buck. I no the b18 come's with 180hp and the h22 come's with 200hp. I am looking for something fast, and still be able drive it every day. I want to be able to beet those people with V8's that think that just because a car has 4 cylinders its slow. Any help would be nice. Thanks.</TD></TR></TABLE>
Old Jan 12, 2004 | 05:55 AM
OTT's Avatar
OTT
he has a s-type, not a Type-S
Type-S is a very rare variation whereas s-Type is quite common
Old Jan 12, 2004 | 05:57 AM
OTT's Avatar
OTT
Type-S = 220bhp H22a plus different gear ratios set for acceleration
JDM only
Old Jan 12, 2004 | 08:51 AM
ludefreek's Avatar
type-s = h22 (DOHC)
s-type = f22 (SOHC accord motor)
Old Jan 12, 2004 | 10:10 AM
lol 4th gen Type S
Old Jan 12, 2004 | 11:31 AM
prelittlelude's Avatar
Default Re: (ludefreek)
do they even call it a s-type, every lude in the world that i have seen that is an S , is just called a Prelude S. you don't hear people saying "Yeah, i got a honda Prelude VTEC-type". its just prelude s. and get a JDM h22a will have alittle higher compression, get you alittle more HP. i am jealous of you money silver paint job
Old Jan 12, 2004 | 02:06 PM
99spanishGT
Guest
Posts: n/a
Default Re: (prelittlelude)
nice paint Did they come stock that color???
perry2929
Aug 12, 2013 05:46 AM
Twilightepitaph
Dec 12, 2004 12:07 AM
coryg79
Oct 28, 2004 01:05 PM
Dave01
Feb 3, 2004 12:14 PM
t0p_sh0tta
Nov 22, 2002 02:45 PM
