Anything else I need to do a 5 lug conversion???
I searched the site for 5 lug conversion topics & just wanted to make sure that what I'm reading is correct. Can I just buy a hub conversion kit, or do those not work??? Or do I need these...
Front and Rear Rotors
Front and Rear Hubs
Upper Lower arms
Front sway bar???
Left and Right axles
front calipers
rear calipers
is there anything else that i need?
I'm assuming that it also may be easier to purchase each corner set up from a junk yard
thanks
mike-dizzle
Front and Rear Hubs
Upper Lower arms
Front sway bar???
front calipers
rear calipers
thanks
mike-dizzle
Re: Anything else I need to do a 5 lug conversion??? (93_pre-lewd)
Front and Rear Rotors . . . YES
Front and Rear Hubs . . . Front knuckles/hubs; rear spindles
Upper Lower arms . . . NO
Front sway bar??? . . . NO
Left and Right axles . . . NO
front calipers . . . YES
rear calipers . . . NO
is there anything else that i need? . . . YES: Front brake pads, ABS wheel sensors
I'm assuming that it also may be easier to purchase each corner set up from a junk yard . . . YES
This parts list has been posted several times in the past few weeks.
h22-eg-hatch
05-09-2015 07:53 AM
Dcsports92
02-27-2008 05:20 PM
