Possible leak?
Old Jul 23, 2005 | 01:13 PM
BB4vTak's Avatar
Default Possible leak?
I have been hearing a Hissing sound when i give the motor load coming from intake.. now back when i did my swap i had to take my throttle body off, and never replaced the gasket.. do you think it is possible that im leaking through that gasket??? Also if that is tha case would it have any affect on the way my car is running.. feels like its running strong sometimes and a bit sluggish at others. any help, advice welcome. Thanks!
Old Jul 23, 2005 | 03:06 PM
BB4vTak's Avatar
Default Re: Possible leak? (BB4vTak)
Bump??? Cmon??
Old Jul 23, 2005 | 11:21 PM
BB4vTak's Avatar
?ttt
Old Jul 24, 2005 | 11:11 AM
BB4vTak's Avatar
BUMP!! HELP!!!
Old Jul 24, 2005 | 11:40 AM
steveobb4's Avatar
You could have a vaccum leak and yes i would replace that gasket. Your pretty close to where i live. If you have a vaccum leak you car will be running rich.(your o2 sensing a lean mixture cuz of vaccum leak then it compensates by adding more fuel. Does your car backfire at all?
Old Jul 24, 2005 | 12:31 PM
specialedition's Avatar
Default Re: Possible leak? (steveobb4)
also take some carb cleaner and spray around the intake manifold gasket if that is leaking like it was on my car it would spray a little coolant on the back of the firewall. Yes the car will run strong as hell sometimes then tend to bog and backfire other times. the carb cleaner trick is how I found my leak hope this helps...
Old Jul 24, 2005 | 01:00 PM
BB4vTak's Avatar
Default Re: Possible leak? (specialedition)
yea it does backfire and bog sometimes.. im going to check all vac lines and replace that gasket.. anything else? you say im close to you.. im on Overland Park Kansas... yourself?
Old Jul 24, 2005 | 01:07 PM
steveobb4's Avatar
i live in emporia. Good luck and let us know after you replace that gasket if it fixes it.
Old Jul 24, 2005 | 01:08 PM
BB4vTak's Avatar
i just looked and found that some vac lines were going to the wrong places.. could this have similar effects?
Old Jul 24, 2005 | 02:12 PM
steveobb4's Avatar
Which ones , i know there is three from the charcoal canister and 3 on the other side of the engine for egr/cruise/and egr solenoid(i think).Pcv valve to intake mani and the iabs.Look in the Faq's and there is a vaccum diagram, thats what i used when i did my swap.
jpm3071
17
Sep 21, 2015 10:23 AM
dpine
Sep 30, 2006 05:35 PM
chu77
Jul 25, 2006 05:03 AM
stwano
Jun 27, 2006 02:50 AM
OrangeBoost
May 9, 2006 04:34 PM
