Compression : Problems Ratio
Old Jul 24, 2005 | 05:56 PM
The Weather Man's Avatar
Default Compression : Problems Ratio
I was just wondering what kind of problems arrise as the compression gets higher. I've heard some things such as past 12.0 ....its harder to start the engine.....don't know if thats bogus or not, but just let me know some. I'm currently working on an n/a setup - and i'm thinking about running the Skunk2 Stage III cams....I know it'll require very high compression to get the most power.....i'm thinking about 13.0
Opinions please.
Old Jul 24, 2005 | 10:30 PM
The_Head's Avatar
Default Re: Compression : Problems Ratio (NaptownKing)
More heat is produced when you raise the compression, and the chances of detonation are higher.
Old Jul 24, 2005 | 10:45 PM
MUGEN_CF4's Avatar
Default Re: Compression : Problems Ratio (The_Head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Head &raquo;</TD></TR><TR><TD CLASS="quote">More heat is produced when you raise the compression, and the chances of detonation are higher.</TD></TR></TABLE>
as a result a good tune and higher octane may be required.
Old Jul 25, 2005 | 04:51 AM
So - would it be safe to use 94octane on 13.0 compression?.....that what i'm thinking about doing - of course with a good tuna to go along
Old Jul 25, 2005 | 04:56 AM
^^^^^ Haha...just read over it....i meant with a good TUNE.....
Old Jul 25, 2005 | 12:29 PM
The_Head's Avatar
Default Re: (NaptownKing)
Yes, it is possible.
Old Jul 25, 2005 | 01:16 PM
SKDRCR's Avatar
Default Re: (The_Head)
You will also go through more gas with the compression being higher.
Good tuning and higher octane gas as suggested before would
be your best bet with this setup
ef_si
Jul 25, 2013 02:09 PM
dc4teg95
Nov 6, 2007 04:18 AM
1.8T_EG
Jul 6, 2004 08:27 AM
kwik93si
Mar 20, 2004 06:37 PM
ITR.00-1282
Mar 30, 2003 09:04 AM
