Idle problem need help asap
Old Jul 29, 2005 | 01:27 PM
eric416's Avatar
Default Idle problem need help asap
I was having the low idle/surging/stalling problem that a lot of other ppl are having. After researching it I found out that the IACV has to be cleaned and the FITV has to be adjusted. Today i decided to fix the problem. First i did the IACV and the car ran fine. Next i did the FITV. Thats when i ran into a problem.
I unbolted the FITV from the trottle body.
Then i turned the white screw as far as it would go in
I bolted everything back up correctly and started the car. At first it idled above 1000rpm. Then as the car warmed up to normal temp the idel went to about 850rpm which is about normal. I thought everything was all good untill i took the car down the block. When i put the car in neutral it idles really low and almost stalls. What did i do wrong?? It hadn't stalled like that in a while and now it happens right after i fix those 2 things. Anyone have any suggestions?
Old Jul 29, 2005 | 02:01 PM
eric416's Avatar
Default Re: Idle problem need help asap (eric416)
Oh yea, its an h22a4 if that matters
Old Jul 29, 2005 | 02:57 PM
flyrod's Avatar
try re-setting the ecu.
Old Jul 29, 2005 | 04:43 PM
eric416's Avatar
Default Re: Idle problem need help asap (flyrod)
***UPDATE***
Just cleaned the EGR valve and reset the ecu. Still no change
When i block the FITV with my finger on cold start up, idle drops. When its warm theres no change.
When i unplug the IACV the engine shuts off when it is cold and also at opperating temp.
Is this supposed to happen?
Old Jul 30, 2005 | 12:29 PM
eric416's Avatar
anyone?
Old Jul 30, 2005 | 12:52 PM
pheurton-skeurto's Avatar
i just put a new intake manifold on my h22a4 and didnt have room for the fitv after the install so i just fabbed a block off plate. i had the same problem with the car dipping really low into rpms and almost stalling, especially when the car was cold. messed with the idle screw and got the idle back up so that its not dropping as low.
Old Jul 31, 2005 | 08:02 AM
eric416's Avatar
Default Re: Idle problem need help asap (pheurton-skeurto)
im gonna mess with the idle screw and see if that helps
Old Jul 31, 2005 | 03:16 PM
eric416's Avatar
anyone have any other ideas. i really need to get this thing running. I'd hate to bring it to a shop
Old Jul 31, 2005 | 07:17 PM
daveedd357's Avatar
what kind of mods do you have to your car. that would help in determining where your problem is starting from
Old Jul 31, 2005 | 08:02 PM
2quik's Avatar
adjust your idle screw accordingly to a point where it wont stall, should be a tad above 850 rpm.
Old Aug 1, 2005 | 11:56 AM
eric416's Avatar
Default Re: Idle problem need help asap (daveedd357)
my mods are i/h/e crank pulley,350 injectors, and a chip. All of the parts have been on the car for 3 yrs so i dont think its any mods.
I tried adjusting the idle screw but it didnt really help, it just makes a hissing sound when i turn it past a certain point.
andysila
Apr 4, 2006 06:46 AM
matt j
Jan 2, 2004 07:21 AM
SyN37
May 10, 2003 10:28 PM
