ignitior test??
Ok i read the instructions for testing the ignitor but i'm a bit confused on these last two steps:
"If there is battery voltage, then check the yel/grn wire between the ECM
and the ICM.
Check the blue wire between the tachometer and the ICM."
how do u check the wire between the ecm and icm? i checked the voltage with the ignitor on and got .25 volts. Is that normal? also how do u check the tach wire?
and the ICM.
ZColeon
Feb 4, 2003 09:34 AM
