Factory LSD installation?
Old Nov 15, 2005 | 05:25 AM
MadCityLude
Guest
Posts: n/a
Default Factory LSD installation?
I had a friend just offer to give me a JDM factory Viscous LSD with the ring gear and speedo gear!
My question is: Will this setup work with my curent setup? (H22, with an F22 tranny)
If so how difficult is installation? (comparing to say an engine swap - or clutch install)
Also: If it will not work what would I need to be able to use it?
And would you recomend using it? Or should I just by the OBX LSD? I can't afford the Quaife no way no how so please don't recomend it!
Or should I just buy a whole new tranny?
Thank you!
Modified by EuroR92Lude at 8:59 AM 11/15/2005
Old Nov 15, 2005 | 05:28 AM
mgags7's Avatar
inside the transmission is probably the hardest work you can do, there are all kinds of bearings, clips, crap, and clearances to worry about....
i have had more than enough problems with differentials....i would pay a shop to do it, or just dont...
oh and ps....i would love to see it if you had a viscous diff.....are you sure its not a torsen type??
Old Nov 15, 2005 | 05:36 AM
MadCityLude
Guest
Posts: n/a
Default Re: (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">oh and ps....i would love to see it if you had a viscous diff.....are you sure its not a torsen type??</TD></TR></TABLE>
I am not sure that is what he called it! I really dont know much abot trannys or differentials!
Old Nov 15, 2005 | 05:38 AM
mgags7's Avatar
Default Re: (EuroR92Lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EuroR92Lude &raquo;</TD></TR><TR><TD CLASS="quote">I am not sure that is what he called it! I really dont know much abot trannys or differentials!</TD></TR></TABLE>
well then i suggest you dont try to install that diff....
Old Nov 15, 2005 | 06:00 AM
MadCityLude
Guest
Posts: n/a
I will prolly have it done for me! Not a big deal!
Old Nov 15, 2005 | 09:31 AM
bad-monkey's Avatar
i'd definitely have the tranny taken out of the car, then take the tranny and the LSD to the shop.
tranny removal/reinstall is at least a $300 charge, and it's something most of us can do ourselves.
i'm pretty sure the diff is a torsen diff--and i'm not sure if it'll fit in an F22 casing.
Old Nov 15, 2005 | 09:44 AM
Honda318dx's Avatar
Default Re: (bad-monkey)
I am convinced all prelude LSDs were viscous, all accord LSDs were torsen..
Old Nov 15, 2005 | 10:00 AM
PirateMcFred's Avatar
Default Re: Factory LSD installation? (EuroR92Lude)
Read this and make your own conclusions.
https://honda-tech.com/zerothread?id=1393262
Oh and next time search before you post.
Pirate
Old Nov 15, 2005 | 02:00 PM
MadCityLude
Guest
Posts: n/a
Default Re: Factory LSD installation? (PirateMcFred)
Thanks for the help Pirate, but I still don't exactly understand!
That whole post was a little over my head when it comes to transmissions!
It sounded like they said it will work! (correct me if I am wrong)
But is that without case modification?
Is this gonna be worth the time and money it will take, or should I just save and buy a new tranny altogether?
Thanks
Old Nov 16, 2005 | 05:47 AM
Funkmaster Ferio's Avatar
For the price you pay to "try" and time to make it work only to find out that it doesn't you could of found yourself a factory lsd equiped unit.
Old Nov 16, 2005 | 06:27 AM
MadCityLude
Guest
Posts: n/a
Default Re: Factory LSD installation? (Funkmaster Ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Funkmaster Ferio &raquo;</TD></TR><TR><TD CLASS="quote">For the price and time you pay to "try" to make it work to only to find out that it doesn't you could of found yourself a factory lsd equiped unit.</TD></TR></TABLE>
Thats exactly what I am thinking!!
manchildteggy
Transmission & Drivetrain
May 1, 2012 10:54 PM
tofast4uh22
Mar 14, 2009 10:08 PM
PrecisionH23a
Apr 29, 2006 09:29 AM
