Compression Testing?
Old Nov 19, 2005 | 10:11 PM
MadCityLude
Guest
Posts: n/a
Default Compression Testing?
Well I just did my first compression test since I put in my swap and am curious as to if everything is still OK!!
Just FYI when I FIRST put in my H22 I did a comp. test and I never looked at it myself. A friend read it while I sat in the car and turned the key. He said then that it was 205-210 on all four!
Now I did one today and the rusults were 190, 210, 210, 220! Since the first seemed kind of low I reran it and it came out at 200-205
So my final was
1- 200-205
2- 210
3- 210
4- 220
Is this normal? acceptable?
Old Nov 20, 2005 | 06:03 AM
97Preludeguy's Avatar
Default Re: Compression Testing? (KillaLude92)
Ideally, you don't want to have a gap of more then ten or so from the highest to lowest number, but I would still say that you're good
Old Nov 20, 2005 | 06:39 AM
mashoutposse's Avatar
How much should it cost to have one done by a shop?
Old Nov 20, 2005 | 07:35 AM
MadCityLude
Guest
Posts: n/a
Default Re: Compression Testing? (97Preludeguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mashoutposse &raquo;</TD></TR><TR><TD CLASS="quote">How much should it cost to have one done by a shop?</TD></TR></TABLE>
Why? Just DIY!
Anyway should I rebuild?
Old Nov 20, 2005 | 09:24 AM
SteveoBA8's Avatar
your good to go
Old Nov 21, 2005 | 12:02 AM
MadCityLude
Guest
Posts: n/a
Default Re: Compression Testing? (SteveoBA8)
So a rebuild wouldn't be necessary based on just these results?
Thanks
Old Nov 21, 2005 | 06:11 AM
GaRn's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KillaLude92 &raquo;</TD></TR><TR><TD CLASS="quote">So a rebuild wouldn't be necessary based on just these results?
Thanks </TD></TR></TABLE>
no way, those are good numbers for sure..
Old Nov 21, 2005 | 09:38 AM
MadCityLude
Guest
Posts: n/a
Default Re: Compression Testing? (GaRn)
Thanks
Old Nov 21, 2005 | 09:43 AM
soundbomber's Avatar
as long as you see less than a 15% variation, you're good..your numbers look great
Old Nov 21, 2005 | 10:55 AM
FlatBlackPrelude's Avatar
Default Re: Compression Testing? (soundbomber)
so how would you do a DIY compression test?
Old Nov 21, 2005 | 11:11 AM
Default Re: Compression Testing? (FlatBlackPrelude)
get your self a compression gauge and spark plug adapter, pull out your spark plug wires, pull out the spark plug from the cylinder being tested...thread the compression tester in...
go inside the car, crank 4-5 times and record the numbers...continue till the end...most people start from cylinder 1 and end at 4
Old Nov 21, 2005 | 11:40 AM
MadCityLude
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">get your self a compression gauge and spark plug adapter, pull out your spark plug wires, pull out the spark plug from the cylinder being tested...thread the compression tester in...
go inside the car, crank 4-5 times and record the numbers...continue till the end...most people start from cylinder 1 and end at 4</TD></TR></TABLE>
joey1320
Honda S2000
Feb 19, 2008 05:33 PM
nicoya_hyphy@yahoo.com
Sep 19, 2007 08:19 AM
xd69
Mar 7, 2006 12:10 PM
snowblind7x
Apr 13, 2005 08:12 PM
ITR77
Mar 11, 2004 11:01 AM
