TB Change and more F22A1
I'm getting a timing belt change on my 96 Prelude S. It has 91,000 miles.
The parts that I was thinking about replacing are the timing belt, water pump, valve cover gasket, cam seal, crank seal, and balance shaft seal. Should I replace all the seals even though there are no leaks?
Should I also replace the balance shaft belt, balance shaft tensioner, and tensioner pulley?
I started looking at some timing belt kits online for an F22A1, and they all come with BS belt, BS Tensioner, and Tensioner Pulley.
Is there anything else I'm missing. I was also thinking drive belts. Someone told me I should just replace the TB, Water Pump, Valve Cover Gasket, and Cam Seal. Someone else told me I should replace everything.
Thanks,
Del
Thanks,
Del
if the tensioner are working properly you have have to replace them, if the seals are leaking yet, i think you should change them, especially if everything is apart, and due to the miles.
hometheaterman
06-04-2010 11:17 AM
The-Kid
02-08-2008 03:47 PM
dELfONiK
02-21-2006 06:37 AM
elpiar
04-06-2005 02:07 PM
