Idle Problem
Old Oct 5, 2006 | 04:06 PM
candymanjl's Avatar
Default Idle Problem
I have a problem maybe you guys can help me out. I am throwing a CEL for my o2 sensor, so i replaced it and reset the ecu and still throwing it. Besides that problem, my car is idling high. When i start it, it idles at 1000rpm or so, but when it reaches opeating temperature it idles at 1700, any idea what this can be? Thanks in advance
Old Oct 5, 2006 | 05:13 PM
951dc5's Avatar
Default Re: Idle Problem (candymanjl)
check for vacuum leaks
Old Oct 5, 2006 | 05:28 PM
candymanjl's Avatar
Default Re: Idle Problem (Prelude951)
your the second person to say that, thanks ill do that
Old Oct 5, 2006 | 08:10 PM
JasonST's Avatar
Check the wiring to ur o2 sensor. Ur car's likely idleing strange because the o2 sensor is not working properly, so ur car is also running very rich, don't run it too long without the o2 sensor not working cause it will clog up ur cat, if u have one, and also foul ur spark plugs. How long have u had an o2 sensor problem? What code is it giving u? The number I mean, cause theres a few different codes that can be cause by ur o2 sensor.
Old Oct 6, 2006 | 03:41 AM
candymanjl's Avatar
Default Re: Idle Problem (JasonST)
Its blinking code 1. I just began getting the code last week.
hickle
12
Feb 8, 2010 07:24 AM
LvN
Oct 11, 2008 07:46 AM
PWRDbyHseries
Feb 22, 2006 04:53 PM
Koyoloeor
Oct 13, 2005 04:57 PM
apok
May 16, 2005 09:52 PM
