H22 vtec sputtering
Old Oct 4, 2006 | 06:31 PM
nah22accord's Avatar
Default H22 vtec sputtering
First off there are no cels. When my car reaches vtec it sounds like it switches over but it sputters and feels and sounds like it is engaging and disengaging. Last night it worked fine. Also it does it in all gears. Any help would be greatly appreciated.
Old Oct 5, 2006 | 05:30 PM
gaborn73's Avatar
Default Re: H22 vtec sputtering (nah22accord)
I too have sputtering among other torubles. This is a recent trouble. I've only had the car for 1700 miles. It's and auto and in "manual" or auto the engine sputters more like bounces off the rev limiter @ 6500 rpm and won't shift. Initially when this started it would "bounce" once and keep on climbing. Now it bounces/sputters at 6500 and stays there. I will post all my troubles in a seperate thread..fyi.
Old Oct 5, 2006 | 06:58 PM
preludedriva's Avatar
clean out your vtec solenoid and check your oil
and for the 2nd post are you throwing codes? if its bouncin off the rev at 6500 you might be in safe mode
Old Oct 5, 2006 | 07:10 PM
JasonST's Avatar
Default Re: (preludedriva)
Hows the timing on ur car? Check ur spark plugs and see if they're running as they should, not rich or lean. Also, check ur grounds, I went over some bumpy road once and knocked my thermostat ground a tad bit loose and on the way home it made my tach bounce a bit and when I engaged vtec it would sputter. Try these things and if it dosen't fix it then shoot me back a reply. O and one more thing, does it feel like ur loosing power when it's sputtering, or bogging at all?
Old Oct 5, 2006 | 07:13 PM
5genprelude's Avatar
First post ya deffintaly check your oil first Vtech runs off of oil pressure as long as theres oil showing up on ur dipstick you should be fine. My vtech cuts out here and there and its always my low oil pressure I just had the problem a couple days ago and added a couple quarts. I don't bout all Vtech ludes but mine goes through oil quite a bit.
Old Oct 5, 2006 | 08:09 PM
manbearpig's Avatar
Default Re: H22 vtec sputtering (5genprelude)
yeah, mine was acting exactly as you describe and I checked the oil..... about 4 mm worth of oil on the dipstick i filled it up, no more feeling like it's banging out at 6500 and it pulls like it's supposed to!
Old Oct 5, 2006 | 09:12 PM
H22a T13's Avatar
Your oil might be low, i got lazy and delayed a change and when i finaly did it was very low, my vtec was doing the same thing, change the oil then if that doesnt work clean the solonid
Old Oct 10, 2006 | 07:55 AM
Default Re: (JasonST)
I just put in a new transmission and on the same night I installed it, I took it out for a test drive, everything worked fine and pulled hard. The next day I drove it to a muffler shop and never hit vtec on the way there, to have my new header and downpipe put on along with getting my exhaust rehung. On the way back I went to go into vtec and that is when the problems started. The oil is full, checked the vtec solenoid and it is clog free and is working and put on new plug wires. One other thing when the rpms get high above 5k the temp gauge starts falling to cold then as soon as I or push the clutch in it goes right back to normal (I first noticed this the night I took it out for a spin but everything was working perfectly even with the temp going to completly cold). The car drives perfectly fine under normal conditions and there are still no cels. I am thinking it could be my distributor finally craping out (It is the same distributor that came with the motor and is internal coil with about 80k - 100k miles on it).Any intput would be greatly appreciatied and thanks again for your time.
Old Oct 10, 2006 | 08:25 AM
Default Re: (nah22accord)
Could a distributor going bad cause driving under normal load conditions seem fine but under heavy load like vtec cause these problems.
Old Oct 10, 2006 | 12:31 PM
alterdcreations's Avatar
i had the same problem with my h22. when i took mines apart i found leaking valve seals, and the o ring fir the center bearing cap was gone(???????)
also plugs were completely fouled. i doubt it is the dissy
Old Oct 25, 2006 | 01:41 PM
Default Re: (alterdcreations)
I am still having the same problems with my vtec. Any help would be greatly appreciated. Thanks
Old Oct 26, 2006 | 07:45 AM
Anybody? I tried searching, but no help.
Old Oct 26, 2006 | 09:31 AM
Someone told me it could be my ecu. But if my ecu was messed up could it be causing this problem and only this. Everything else seems fine.
sleepy5950
Jan 15, 2012 07:48 PM
GSR coupe
Feb 27, 2010 12:11 PM
kornerk12
Dec 27, 2006 01:02 PM
VolkswagenWHO!!!
Nov 15, 2006 06:27 PM
onesikdc2
Aug 16, 2005 03:14 AM
