constant stuttering
Old Sep 28, 2006 | 07:43 PM
sheBangZ's Avatar
Default constant stuttering
i've got an h22 teg with a few issues i cannot seem to pinpoint anymore. Shaky idle, surge from 1k to 100 rpm's form time to time, a few times it'l hit wut seems like fuel cutoff/rev limitor at 3500 rpm's, exhaust popping, whenever i let off gas the car would stutter, lagging every once in a while, seems like it lost power overall. I've tryed to narrow it down by changing the fuel filter, fuel injector screens, cap and rotor, spark plug wires, using ngk r plugs, alternator belt(thot it might have been slipping), cleaned iacv and screwed the fitv back in, new thermostat ect. ect. I pulled the plugs to check them out, the tip is a nice brown and half the bototm porcelain is black while the other half is still white. I have quite a few exhaust leaks but they are al after the 02 sensor so i did'nt think that would affect the car much other than being noisy and annoying. when i cleaned the iacv, i noticed the end plastic part was cracked , so i put gasket maker on it to seal it up. I'm currently using a turbogixxer chipped p28 on her and she ran fine on this until a few weeks ago. I honestli have no idea anymore on whats causing the car to do this and it seems to get worse every day and more constant. would an o2, or iacv go bad without a cel? any advice or help would be appreciated as i need to get this fixed before i damage the motor.
and also i do not have any cel's either.
Old Sep 28, 2006 | 07:51 PM
JasonST's Avatar
Default Re: constant stuttering (sheBangZ)
Does it always hit this revlimiter at 3500 rpms? Check ur timing, check the belt too make sure it's dead on TDC. Maybe try a compression test.
Old Sep 28, 2006 | 08:03 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: constant stuttering (JasonST)
id check timing of your cams first....
Old Sep 29, 2006 | 06:20 AM
sheBangZ's Avatar
i've alredy done a compression check and cam timing is on. its gotta be sumthing simple thats causing this?
Old Sep 29, 2006 | 08:45 AM
Daniel M's Avatar
Do you throw any cells if you hold it in wot? EGR Ports clogged??
Old Sep 29, 2006 | 08:45 PM
sheBangZ's Avatar
the egr is not hooked up, and i think the cel i get at 7700 is the cel shiftlight.
Old Sep 30, 2006 | 05:21 AM
sheBangZ's Avatar
bump
Old Sep 30, 2006 | 08:33 PM
sheBangZ's Avatar
on way jome today i downshifted, and the cel fickered for a few secs and come off. any ideas? i check for cel's and nothing.
Old Oct 1, 2006 | 05:01 AM
sheBangZ's Avatar
up up up and away. need help!
Old Oct 1, 2006 | 06:37 PM
sheBangZ's Avatar
bump it up. i need help!
Old Oct 2, 2006 | 06:28 AM
sheBangZ's Avatar
bump, i still got nothing.
Old Oct 2, 2006 | 09:31 AM
midnitesol's Avatar
ive had my o2 be unplugged and still throw no code it just ran like **** until i pucnched so it could be that but also double check all ur grounds.
Old Oct 2, 2006 | 10:07 AM
sheBangZ's Avatar
today she would not want to move for a few seconds. I was thinking o2, map, or tps would be mafunction and not throwin a light. I've also already checked the grounds.
Old Oct 2, 2006 | 09:19 PM
sheBangZ's Avatar
bump
Old Oct 3, 2006 | 11:49 AM
LowTec MOHawk's Avatar
the blinking MIL is indicating that a very bad missfire is currently happening. the surging idle souds like u have a HUGE vacuum leak, best way to find that is to use a smoke machine (wich most people dont have) or good old brake cleaner. just spray around the manifold until the rpms shoot way up then you've found it. but in this case u might be able to actually hear the manifold leak. thats where id start. as for the missfire if your positve that the spark is good then it might be a fuel delivery problem or a volumetric efficiency problem. get some vacuum readings, do a running compression test and a leak down test. that should give you some sufficent data on where to look for the problem
Old Oct 3, 2006 | 11:51 AM
ohhh the other thing make sure that there isnt any desiel fuel in your tank......i know it sounds dumb but i cant even tell u how many times ive seen it
98greensi
Jul 23, 2011 07:26 AM
milanocivic
Feb 20, 2009 08:26 PM
johnjohn072002
Jun 7, 2007 01:04 PM
hkrichard
20
Jun 2, 2006 09:03 AM
wrXtian
Jul 30, 2002 05:09 PM
