cel code 15. help!!!!!!
Old Oct 4, 2006 | 02:06 PM
atm3535's Avatar
Default cel code 15. help!!!!!!
When i turn my key to the on position when the fuel pump kicks on and all... my ignition coil is sending out quick bursts of spark. then a few seconds later...the sparks stop. Then when i turn the motor over to start it, there is no spark at all?? Did anyone have an issue like this or knows what might be wrong?? I'm getting code 15 on the cel which is ignition system. thanks
Old Oct 4, 2006 | 02:36 PM
94vtirozguy's Avatar
check the connectors under the hood, that was my fix for this code. From memory it was one close to the fuse box.
Old Oct 4, 2006 | 06:07 PM
JasonST's Avatar
Default Re: (94vtirozguy)
What 94vtirozguy said, also check all ur grounds, especially thermostat ground, make sure they are all nice and tight, make sure ur ignition wires are wired up correctly, not corroded or grounding out, and tight at the connectors and not falling out.
Old Oct 4, 2006 | 06:13 PM
atm3535's Avatar
ok thanks guys i'll try that
civicboy420
Sep 25, 2011 06:05 PM
dump3deg6
Jul 20, 2009 09:43 PM
Dohc 4door Rye
Jun 16, 2006 04:53 PM
PowerHouse
Nov 12, 2004 04:01 AM
