...Tuning Question...
Old Sep 28, 2006 | 01:00 PM
K-Spec's Avatar
Default ...Tuning Question...
I got my car tuned in California where the air is a lil cooler and I'm now living in Arizona where it's like 3,000ft above sea level and it's a lil hotter here (air is thinner also). Just wanted to know if driving here in AZ hurt/effect my performance/engine? (ie. a/f ratio, running rich/lean, etc.)
Old Sep 28, 2006 | 01:04 PM
92blkJDMh22's Avatar
say you were going from a mid summer to Miami Tune to mid winter in colorado... maybe....
im sure the performance would be diff due to the air, but im not sure how much a tune would be able to do....... but then again, i dont know, thats just where logical thinking took me....
Old Sep 28, 2006 | 01:12 PM
petern101's Avatar
Default Re: (92blkJDMh22)
you don't have a wideband? cause if you did, you could figure if you were running lean.
what was your a/f after tune in warmer climate?
Old Sep 28, 2006 | 02:37 PM
K-Spec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92blkJDMh22 &raquo;</TD></TR><TR><TD CLASS="quote">say you were going from a mid summer to Miami Tune to mid winter in colorado... maybe....
im sure the performance would be diff due to the air, but im not sure how much a tune would be able to do....... but then again, i dont know, thats just where logical thinking took me....</TD></TR></TABLE>
ya, i figured the elevation would have something to do with it...but i wasnt sure if this would hurt my car--getting it tuned at sea level and driving it at 3,000ft above sea level everyday.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">you don't have a wideband? cause if you did, you could figure if you were running lean.
what was your a/f after tune in warmer climate?</TD></TR></TABLE>
nah, i dont have a wideband...how much are those? I think my a/f was at about 14.1
Old Sep 28, 2006 | 05:41 PM
98vtec's Avatar
moderator emeritus
Default Re: (khalal538)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by khalal538 &raquo;</TD></TR><TR><TD CLASS="quote">ya, i figured the elevation would have something to do with it...but i wasnt sure if this would hurt my car--getting it tuned at sea level and driving it at 3,000ft above sea level everyday.
nah, i dont have a wideband...how much are those? I think my a/f was at about 14.1</TD></TR></TABLE>
if anything it would run a little richer since you are higher in elevation and its a TAD hotter. 14.1 is a little lean to make the best power, so based on what you are saying, you could actually be running around the correct afr at WOT.
widebands range from 300-600
i run a zeitronix zt2
Old Sep 28, 2006 | 06:26 PM
K-Spec's Avatar
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">
i run a zeitronix zt2</TD></TR></TABLE>
would a car running lean smell, look, sound, feel, (taste) different? And what's your AFR?
Old Sep 28, 2006 | 07:41 PM
98vtec's Avatar
moderator emeritus
running a little lean wont smell like anything. after an interstate pull during logging, it will smell like fuel after i let off, but thats about it. My afr is about 13:1 at WOT and 15.0 at part throttle.
what are you smelling?
Old Sep 29, 2006 | 01:41 AM
K-Spec's Avatar
Not smelling anything but fuel i'm burning at 8200rpm
Old Sep 29, 2006 | 07:32 AM
PrecisionH23a's Avatar
Default Re: ...Tuning Question... (khalal538)
Yes, it will affect the tune.
The PLX widebands go for about 315. I use them to tune every car that I do.
Let me know if you need one
Old Sep 29, 2006 | 09:23 AM
K-Spec's Avatar
Default Re: ...Tuning Question... (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Yes, it will affect the tune.
Let me know if you need one </TD></TR></TABLE>
how much do you sell them for? (H-T discount?)
and would it affect the tune to a point where it's noticable?
Old Sep 29, 2006 | 10:33 AM
98vtec's Avatar
moderator emeritus
depends on how much of a climate and elevation change you went through. But yes, given certain circumstances, it can be noticeable.
Old Sep 29, 2006 | 11:11 AM
K-Spec's Avatar
Default Re: ...Tuning Question... (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">depends on how much of a climate and elevation change you went through. But yes, given certain circumstances, it can be noticeable.</TD></TR></TABLE>
3000ft elevation and 5-10 degrees hotter
Old Sep 29, 2006 | 11:15 AM
98vtec's Avatar
moderator emeritus
in cali, you were at sea level?
Old Sep 29, 2006 | 12:31 PM
K-Spec's Avatar
close, very close....
Old Oct 1, 2006 | 05:35 AM
94civic18's Avatar
Ok well, I have a house in Colorado Springs (suburb) which is at 7800ft, then Cleveland Ohio which is 200ft? so im dropping 1¼ MILE, and trust me I noticed the difference on my NA setup but I have the same question you do so any answers would help ALOT
tahnks
H22Honda98
Dec 7, 2010 09:10 AM
jr408
Mar 21, 2008 06:06 AM
jr408
Mar 20, 2008 09:20 AM
99blackdc2
Aug 30, 2006 04:08 AM
Flux
Oct 9, 2004 03:41 PM
