Engine stalls at idle
Old Jan 14, 2007 | 04:41 PM
ZXRider's Avatar
Default Engine stalls at idle
To summarize the situation. I just recently rebuilt my cylinder head on my 98 Prelude. Now that everything is back together, the car starts but once it warms up the engine does not want to idle and dies.
The ECU throws 3 codes
13 Barometric Pressure Circuit
14 Idle Control System Malfunction
Idle Air Control Valve Circuit Failure
17 Vehicle Speed Circuit Malfunction
This is a previous post I made regarding this problem.
https://honda-tech.com/zerothread?id=1859428
I ended up replacing the IAC and the MAP sensor with a good condition working one and it still does the same thing.
I know I got the timing on correctly. It's not the timing.
So im trying to figure out what else could cause this?
Old Jan 14, 2007 | 04:46 PM
roller3804's Avatar
do you have a helms manual?
Old Jan 14, 2007 | 04:47 PM
ZXRider's Avatar
Default Re: (roller3804)
Yes I do.
Old Jan 14, 2007 | 07:26 PM
roller3804's Avatar
Default Re: (ZXRider)
sweet.
take the codes you pulled and go through the troubleshooting for each one. If you need help hollaa
Ohmega
Jul 21, 2018 12:00 AM
DirtyRussian
13
Mar 29, 2016 09:14 AM
skinney6
79
Aug 3, 2012 07:28 AM
vdawg559
Jun 11, 2008 04:31 AM
firefly
Oct 12, 2001 08:39 PM
