H22 EG Problems
Old Jan 12, 2007 | 01:48 AM
DEL HATCH's Avatar
Default H22 EG Problems
I have a 92 cx with a JDM h22. While driving to work this morning, when I went to shift into 2nd gear it was like I was in nuetral. I went through all the gears and the same thing. Nothing was engaging. Anyone have any ideas as to what this might be?
Thanks
Old Jan 12, 2007 | 02:17 AM
roller3804's Avatar
shift linkage most likely. Can you be a little more specific?
Old Jan 12, 2007 | 02:20 AM
DEL HATCH's Avatar
Default Re: (roller3804)
Thats all I can really explain now, I'm at work. I just went to shift into 2nd gear and when I depressed the clutch the car was just like in nuetral. I press the gas while in gear and it just revs up.
Old Jan 12, 2007 | 04:52 AM
preludeguy_92's Avatar
Default Re: (DEL HATCH)
You may need a new clutch. Can you still feel the gears when you shift?
Old Jan 12, 2007 | 05:27 AM
DEL HATCH's Avatar
Default Re: (preludeguy_92)
When the car is in gear and I depress the clutch there is a slight grinding like noise.
Old Jan 12, 2007 | 06:04 AM
There is a slight grinding but the car will not move correct?
Old Jan 12, 2007 | 06:14 AM
mgags7's Avatar
your shift cables broke, and you're not actually in gear, go pop the hood and use your hand to switch gears with the car off, make sure they feel alright that way
Old Jan 12, 2007 | 06:15 AM
DEL HATCH's Avatar
Correct sir. Its like the car is in nuetral.
Old Jan 12, 2007 | 06:16 AM
DEL HATCH's Avatar
Default Re: (bb4ever)
Thanks for the response. I will have to wait until I get off work in a few hours to check that. Thats alot better news than tranny problems.
Old Jan 12, 2007 | 06:48 AM
GO-FIGHT-KILL's Avatar
I agree with bb4ever... Sounds like a shifter cable problem. Won't be a hard fix at all.
Old Jan 12, 2007 | 01:28 PM
2000Pimpinex's Avatar
Default Re: (GO-FIGHT-KILL)
Ok, bad news is it isn't the shift cables. The speedo is moving. My mechanic stopped by and we checked the shift cables first. They are moving properly. He noticed the speedo moving and the noise coming from the tranny. So I guess I need to start saving. I really hate the H22 tranny's.
Old Jan 12, 2007 | 03:18 PM
Default Re: (2000Pimpinex)
So your looking at a new diff. Might as well get a quaif while your at it.
Old Jan 13, 2007 | 01:21 AM
DEL HATCH's Avatar
The tranny already had a quaife in it.
ALL IMPORT
Sep 1, 2006 08:01 PM
trianglegreg
Jan 4, 2006 03:13 PM
eMbrace
May 14, 2005 07:47 AM
Taikonaut
Dec 15, 2003 04:37 PM
htchbak
Sep 12, 2003 03:02 PM
