Throttle Cable problems
Old Jan 13, 2007 | 12:29 PM
HondaLude93's Avatar
Default Throttle Cable problems
I recently removed the plate under my intake manifold to keep all ports open for v-tec to be constantly running on my JDM H22. Now i have acceleration problems and it shifts weird too. I think my throttle cable seems too long because of the change, even when iv adjusted it. Dont know what to do!
Old Jan 13, 2007 | 12:56 PM
DCxMagus's Avatar
Default Re: Throttle Cable problems (HondaLude93)
that plate isn't to keep VTEC engages all the time thats just for the IABs VTEC is controlled by a solenoid which receives a signal from your ECU to push the pin over so that you switch to the higher profile rocker arms.
why would you want VTEC always on anyway? unless you are prepping a race engine but then you would just switch to high profile cams and disable VTEC entirely.
and if you DID keep VTEC engage the whole time of course your going to have acceleration problems VTEC is meant for high rpm, having VTEC engaged before like 4K is utterly pointless and you end up losing power if your not reving your engine sky high every time you take off.
Removing the IABs is going to give you slow acceleration as well because you are stuck on the runners that make power past 3.5K(I believe is when the short runners make power)
Old Jan 13, 2007 | 01:00 PM
Hawkze_2.3's Avatar
Bahaha!!! #1 That plate has nothing to do with VTEC and #2 having VTEC on all the time is a horrible idea....you'll have no power down low.
Old Jan 13, 2007 | 02:20 PM
Default Re: Throttle Cable problems (DCxMagus)
i had a friend do it to his gsr. no problems, more air.?
Old Jan 14, 2007 | 09:54 AM
BlUAc's Avatar
well when you put the im back together did you use the same gasket or did the gasket stay on the iab so there is no gasket, are you getting any cel?
Old Jan 14, 2007 | 12:28 PM
Default Re: Throttle Cable problems (BlUAc)
there is a gasket. iv heard about this being done a few different times and when i do it i have problems all the sudden. there was a gasket on top and bottom of the plate and now there is just one and the plate with the butterfly valves is in my garage. should i jus put everything back together
Old Jan 14, 2007 | 01:16 PM
ninja 6's Avatar
put the iab plates back on you noob.
Old Jan 14, 2007 | 03:33 PM
Default Re: Throttle Cable problems (ap)
Problem solved, thanks for the help from the non a holes. Car runs fine=secondary butterflys out!
cr757gsr
Oct 9, 2009 01:01 PM
Jizzmaster Zero
Oct 1, 2005 09:08 AM
ScottEK
Oct 8, 2004 08:42 PM
Quiks66
Nov 6, 2003 09:00 AM
sampsonnight
Apr 17, 2002 01:25 AM
