MIL Codes
Old Jan 6, 2007 | 04:20 PM
ZXRider's Avatar
Default MIL Codes
I recently rebuilt my cylinder head and I just got everything back together.
I ran a compression test this morning and I got:
Cylinder 1: 230
Cylinder 2: 230
Cylinder 3: 235
Cylinder 4: 235
Now the problem is that the car does not want to idle. When I start it up the RPMs go up but when it warms up and the RPMs start coming down it just dies on me.
I have checked ever electrical connector and vaccuum connection and everything seems correct.
My check engine light did come on so I checked the MIL codes and got:
13 Barometric Pressure Circuit
14 Idle Control System Malfunction
17 Vehicle Speed Circuit Malfunction
Well I probably know that 14 means my IAC valve is bad but I have'nt a clue what the other ones mean...any ideas?
Thanks.
Old Jan 6, 2007 | 11:50 PM
ZXRider's Avatar
Default Re: MIL Codes (ZXRider)
anyone?
Old Jan 7, 2007 | 11:39 AM
ZXRider's Avatar
C'mon...someone must have some information about this....
Old Jan 7, 2007 | 11:42 AM
E-Money's Avatar
what car?
Old Jan 7, 2007 | 12:15 PM
ZXRider's Avatar
Default Re: MIL Codes (E-Money)
1998 Prelude base.
5 spd California emissions.
Old Jan 7, 2007 | 12:29 PM
E-Money's Avatar
were you shorting out the ecu or using a scanner?
Old Jan 7, 2007 | 12:37 PM
ZXRider's Avatar
Shorting out the ECU
Old Jan 7, 2007 | 09:49 PM
E-Money's Avatar
the site i used, some toronta prelude site told you what was wrong/parts
Old Jan 7, 2007 | 10:05 PM
RCautoworks's Avatar
Are the plugs in the right spot, the iacv code is what is causing the idle issue. If you ever unplug an iacv at a cold idle then let the car warm up, the idle slowly drops and the car shuts off
Old Jan 7, 2007 | 11:04 PM
ZXRider's Avatar
Default Re: MIL Codes (90blackcrx)
Thats what exactly happens....with or without the IAC....
laloquera916
Honda Civic (2001 - 2005)
Mar 13, 2016 01:33 PM
Stovepipe
Honda CR-V & Element
Oct 29, 2012 04:43 PM
Mishako129
Jul 21, 2012 07:43 PM
Smitty2000
Mar 23, 2008 09:51 PM
Blown383
Mar 12, 2008 10:20 PM
