5th gen HEADLIGHT PROBLEM!
Old Jan 9, 2007 | 03:47 PM
tai_hir's Avatar
Default 5th gen HEADLIGHT PROBLEM!
hi all, my main beams are playing up, its the driver side, i have taken it to the garage and have changed the bulb twice aswell as the fuse, the passanger side beam is normal and the driver side seems low? any suggestions on how to sort it out? it isnt an earth problem as iv had that checked. wiring problem? the bulb seems to blow/burn out!!!!
Anyone have similar problems?
thanx
Old Jan 9, 2007 | 03:53 PM
KEVLARsh's Avatar
Default Re: 5th gen HEADLIGHT PROBLEM! (tai_hir)
double check it the rigth bulb going in, and the correct rated AMP, not sure whatelse
Old Jan 10, 2007 | 04:06 AM
tai_hir's Avatar
Default Re: 5th gen HEADLIGHT PROBLEM! (DK-Kip)
hi, yeah thanx for the reply, the bulbs are the same as i have swapped the driver side bulb(dim one) for the passanger side one and it kinda swaps the problem back to the driver side one, so it seems more of an electrical wiring problem. il just have to take it to the dealers and see what happens, thanx
Tvg9
Lighting
May 28, 2014 09:25 AM
Chuethou_b18c5
Honda CR-V & Element
Jun 7, 2012 10:56 PM
jbond03civic
Honda Civic (2001 - 2005)
Sep 25, 2007 02:09 AM
bass2dark
Jul 6, 2004 11:59 PM
Accorddrver
Apr 27, 2004 09:41 AM
