lowering spring set up
Old Jan 7, 2007 | 07:29 PM
preludefien
Guest
Posts: n/a
Default lowering spring set up
dose anyone know were i can find some lowering springs. i can find the springs but they only lower up to 2in. i want to be able to tire tuck. anyone have any suggestions of were to check...
Old Jan 7, 2007 | 07:37 PM
ethereal2pt2's Avatar
Default Re: lowering spring set up (preludefien)
coilovers.
Old Jan 7, 2007 | 07:39 PM
preludefien
Guest
Posts: n/a
Default Re: lowering spring set up (_BB6)
yea i have coilovers and they ride like crap when i lower then that low so i wanted to get some lowering springs because i heard that they ride a lot better at that level
Old Jan 7, 2007 | 07:45 PM
kdt3's Avatar
nuespeed race, skunk2
Old Jan 7, 2007 | 07:48 PM
preludefien
Guest
Posts: n/a
Default Re: (kdt3)
were can i find a set...i swear ive checked everywhere...ebay and every site...
Old Jan 7, 2007 | 07:49 PM
mrkal's Avatar
Default Re: (kdt3)
i've sometimes see the eibach ground control coilovers on ebay
Old Jan 7, 2007 | 08:01 PM
preludefien
Guest
Posts: n/a
Default Re: (mrkal)
yea those drop up to 2inches..i need more..more like 4...
Old Jan 7, 2007 | 09:08 PM
nonvteclude's Avatar
Default Re: (preludefien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by preludefien &raquo;</TD></TR><TR><TD CLASS="quote">yea i have coilovers and they ride like crap when i lower then that low so i wanted to get some lowering springs because i heard that they ride a lot better at that level</TD></TR></TABLE>
either way dropping the car that low with coilovers or springs the ride quality will suck.
Old Jan 7, 2007 | 09:57 PM
madcatz's Avatar
yo do realize that there is a limit to when you lower to an extent you start to loose ride quality?
You can only lower so far. If you want to "Tuck Tire" buy some bigger rims and tires. Why anyone wants to do that is beyond me. Not always does lower = better.
Think about what you want to get out of your suspension and then come back and tell us. From there we can tell you what will work
It sounds like you have some OTS POS Coilovers and you blame the settings rather than the operator.
What coilovers do you have. What are they set at. What is your shock dialed at? (If they are adjustable)
We need more to go on that I need to be sitting on the ground and handle like it just came off the showroom floor. You cant have both. Period. You sacrifice ride quality for stiffer springs/shocks.....you sacrifice your height at how aggressive you can drive and push your setup by getting a softer setting.....follow?
If not cut your gawd damn springs and drive into a wall
Old Jan 8, 2007 | 09:12 AM
maverik's Avatar
Default Re: (madcatz)
you're not going to have a smooth ride at all if you want to drop your car 4 in. buddy
Old Jan 8, 2007 | 09:29 AM
championshipwhite93si's Avatar
Default Re: (maverik)
yeah ride quality sucks at the low of a height. i know.. i have coilovers and im pretty low. but, i like how the car looks, and the spring rates arent harsh enough for me to complain. i just really need some adj. struts and it would be peachy..
Old Jan 8, 2007 | 11:39 AM
Default Re: (championshipwhite93si)
get an air ride suspension system haha
Old Jan 8, 2007 | 11:44 AM
h22aBB4's Avatar
by coilovers, do you mean a set of spring/shocks, or springs with an adjustable sleeve?
Old Jan 8, 2007 | 02:48 PM
preludefien
Guest
Posts: n/a
Default Re: (h22aBB4)
ok i have KYB GR-2 GR2 shocks with dropzone coilovers that are ajustable...you can tuck tire with them but they ride like ****...my friend said to get lowering springs because they ride a hell of a lot better...so i was looking around and they only drop up to 2in that i can find...so i guess is should scrap the springs because they dont ride that much better or give me the drop that im looking for...and by the way i just want it that low bc i like the way it looks...
Old Jan 8, 2007 | 04:03 PM
h22aBB4's Avatar
The reason lowering springs ride better is because they dont lower it as much lol. I dont have any experience with "real" coilovers, but maybe try a set engineered to work together, like tein or Form & Function.
Old Jan 8, 2007 | 05:59 PM
PWRDbyHseries's Avatar
I have Eibach Sportlines and min is pretty low and the ride is nice. not to bumpy. but i do need to get struts, blown stocks suck
Old Jan 8, 2007 | 06:07 PM
k_lude's Avatar
Default Re:
stay with the coilovers...you can at least raise your car from time to time...but i believe there are no springs that drop that low anyways.
Old Jan 8, 2007 | 06:12 PM
Default Re: Re: (k_lude)
if you're so desperate to drop it, go ghetto and heat em up with a torch!
/sarcasm
Old Jan 9, 2007 | 07:11 AM
Russ713's Avatar
dAng!
Default Re: Re: (_BB6)
I have a set of Skunk2 lowering springs if you're interested.
I'm putting mine back to stock. I bought the prelude already lowered, but since it's going to be just a spare car, I don't need it lowered.
Old Jan 12, 2007 | 02:21 PM
bigred!'s Avatar
get coilovers
JDM ej1
Apr 21, 2004 05:03 AM
scatuli
Apr 3, 2004 01:55 AM
2 point 0
24
Apr 2, 2004 07:11 PM
bigmouthcivic
Aug 7, 2003 12:29 PM
preludeChaos
Oct 9, 2001 07:28 AM
