replace main relay still having problems
Old Jan 7, 2007 | 01:28 PM
LudeJdm's Avatar
Default replaced main relay still having problems
ok i replaced the main relay with a used one i got from ebay..car started up great but the next day when i went to the mall...i went to start the car and it would start but then die out...it would start that make a guzzling sound and then die out...then i would have to wait a few minutes to start the car up again...what else could be the problem...
Modified by 94_SI_lude at 2:57 PM 1/7/2007
Old Jan 7, 2007 | 02:18 PM
Apex1972's Avatar
Default Re: replaced main relay still having problems (94_SI_lude)
As cheap as a new relay is (45.00) why would you buy a used one?????
Old Jan 7, 2007 | 03:31 PM
britishdude's Avatar
Default Re: replaced main relay still having problems (Apex1972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Apex1972 &raquo;</TD></TR><TR><TD CLASS="quote">As cheap as a new relay is (45.00) why would you buy a used one?????</TD></TR></TABLE>
I second that, it dosn't pay to buy a part like that second hand especially from a source with unknown history. Better getting new parts on items like electrical, at least you can return it if it's the wrong or faulty new part. And you know it should have a full life expectancy.
Old Jan 7, 2007 | 04:05 PM
LudeJdm's Avatar
Default Re: replaced main relay still having problems (britishdude)
do you think i was sold a faulty relay? or could it be something else?
Old Jan 7, 2007 | 06:21 PM
SteveoBA8's Avatar
Get a new relay.
Old Jan 7, 2007 | 08:30 PM
LudeJdm's Avatar
where do you get a brand new relay for 45 at? dealer sells it for $77
Old Jan 7, 2007 | 08:35 PM
Hawkze_2.3's Avatar
You could also check the ignition switch or the ignitor (in the distributor).
Old Jan 7, 2007 | 10:36 PM
LudeJdm's Avatar
Default Re: replaced main relay still having problems (Hawkze_2.3)
how can the ignition switch be a problem?
Old Jan 8, 2007 | 07:13 AM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94_SI_lude &raquo;</TD></TR><TR><TD CLASS="quote">how can the ignition switch be a problem? </TD></TR></TABLE>
If the ignition switch is old and worn, the car will randomly die...that's probably not it, but it doesn't hurt to check.
Old Jan 8, 2007 | 09:33 AM
championshipwhite93si's Avatar
shoulda bought mine, instead of getting ripped off and still not having a car that runs
Old Jan 9, 2007 | 09:32 PM
LudeJdm's Avatar
Default Re: replaced main relay still having problems (championshipwhite93si)
anyone know if Mitsuba RZ-0159 are compatible with 4th gen preludes?
Old Jan 10, 2007 | 04:27 AM
Apex1972's Avatar
If the plug is the same, it will work. Sorry for being a smart@ss in my first reply. You can get a aftermarket at any parts store for about 45.99. Ask for a 90-93 Accord though.
Old Jan 10, 2007 | 04:25 PM
LudeJdm's Avatar
could it be a bad ignition coil?
nismogrendel
Apr 24, 2010 01:43 AM
r1ch1e
Nov 15, 2008 06:12 AM
ninjagaiden
13
Jul 6, 2007 03:44 PM
4dohs4mohoes
Nov 24, 2006 11:17 PM
triple_s1x
Feb 27, 2005 11:10 AM
