Code 12
Old Jan 10, 2007 | 12:02 PM
alexsracing's Avatar
Default Code 12
My prelude h22 is throwing a code 12- EGR Valve Lift Sensor. Searched and found some threads on removing the egr. I want to be sure that if I block it off, the code will still show but the motor will run fine correct? The motor is idling rough and surging from time to time. If blocking it off but keeping the egr valve there means motor runs fine but cel stays on that is fine. Just want to be sure that will solve the motor problem.
Old Jan 10, 2007 | 07:12 PM
1GPlusSH's Avatar
Default Re: Code 12 (alexsracing)
It's not definite that it will solve your problems, but it should run better if you're having problems with it . And yes, the code will stay on.
Gebo
Nov 1, 2016 09:09 PM
snowblind7x
Jan 28, 2010 07:37 AM
technine
Apr 18, 2007 10:51 AM
DC 2
Mar 26, 2004 10:05 PM
