code 9
Old Jan 22, 2014 | 09:43 AM
bgnbgok's Avatar
Default code 9
cylinder sensor can it be rebuilt or do you replace it
Old Jan 22, 2014 | 10:51 PM
holmesnmanny's Avatar
Default Re: code 9
Never heard of it being rebuilt before. You can try the junkyard to pull another. They don't normally go bad. However, from what I've seen people normally get that code when the distributor shaft bearing goes bad and starts slewing red dust around the distributor and blocking the signal the distributor sensors are supposed to give.
Old Feb 13, 2014 | 01:36 PM
furious94ls's Avatar
Default Re: code 9
Just had this on my 95 Prelude S. I replaced the distributor and all is well again. I had red dust in my cap, rotor was worn badly. Sad part is it wasn't even the original distributor. I got a deal on one from a reputable seller on ebay. Time will tell with this one.
Old Feb 13, 2014 | 02:45 PM
you can just replace the bearing and spray out the dizzy with some electrical parts cleaner and be good to go ... you can get the bearing from napa
carlos8
Dec 9, 2014 11:03 AM
Juan_Mitosis
Mar 2, 2009 02:04 PM
staticrex
Jun 9, 2004 12:13 PM
Slatelude
Oct 13, 2003 05:26 PM
az17xscrub
14
Jul 27, 2003 10:30 AM
