Brake lamp light in cluster "ON"
Old 02-18-2014, 07:10 AM
integra_101's Avatar
Default Brake lamp light in cluster "ON"
So my prelude is a spoiler-less prelude. I recently put on a trunk with a spoiler. I had to swap the harness and use the spoiler trunk harness. Then I had a brake lamp light on, which makes sense because I didnt have the spoiler brake light plugged in.
Now I switched back to my spoiler-less trunk with the harness it belongs to, and the light is still on. none of my brake lights are burnt out.
What could it be?
thanks
Old 02-18-2014, 07:24 AM
goldsy's Avatar
Default Re: Brake lamp light in cluster "ON"
First thing to do is make sure your brake fluid is topped up. Low brake fluid will pop that light on.
Old 02-18-2014, 07:49 AM
Its between the MIN and MAX line. More towards the MAX.
Old 02-18-2014, 12:04 PM
BergRacing21's Avatar
i would retrace your steps through the spoiler harness and just make sure nothing got knicked or cut and make sure all the plugs are connected and in tight.
Old 02-18-2014, 03:07 PM
The harness is good. Although I did have to re solder the ground wire in the middle of the harness and the 2 rear bumper lights.
I had to do it when I put the spoiler trunk on. and then again when i put back the spoiler-less trunk
chillerice
Lighting
08-09-2014 07:19 AM
spicyy
09-23-2008 08:47 PM
bobmugen
01-30-2008 03:37 AM
depulse
08-25-2006 02:15 PM
cloudx71
03-21-2005 10:27 PM
Quick Reply: Brake lamp light in cluster "ON"
