HELP Uncontrolled chassis movement
Old Feb 20, 2014 | 10:26 AM
ej6sir-t's Avatar
Default HELP Uncontrolled chassis movement
see video for problem
no suspension play
new shocks in rear
*** meter tells me the problem is with the right side of the car but that's not always correct
only happens above 65 when turning left HARD
sometimes notice handling imperfections at lower speeds again turning left only
Old Feb 20, 2014 | 01:49 PM
David77's Avatar
Default Re: HELP Uncontrolled chassis movement
looks like possibly the toe is not aligned right in the rear. My 96 accord did this in the winter. have you had an alignment?
Old Feb 20, 2014 | 03:00 PM
BlackCatt's Avatar
Man that is severe. I would give all the running gear a thorough check
over. Something is badly out of whack. Check your wheel alignment is ok,
check your tyres (sometimes a bulge in the surface can be a big problem)
+ balance of wheels. Check all your suspension system, shocks, springs,
bushes. Look for any damage to control arms etc. Check rims for any
damage distortion. It would help if you can also advise what springs
shocks you are running and if they are adjustable what settings you are
running. In the meantime i would be fn extremely careful driving your lude
until you diagnose the problem. Also has the lude been in a serious
smash at some time, maybe the chassis is out of alignment. GL with it.
Old Feb 20, 2014 | 03:01 PM
ej6sir-t's Avatar
No and your not the first to recommend. I'm really stubborn and feel this isn't the problem but I'm starting to think it just might be
Old Feb 20, 2014 | 04:20 PM
preludeNApower's Avatar
1st thing to do is get it on a rack
Old Feb 20, 2014 | 05:40 PM
snobordboy's Avatar
Moderator
Damn yeah, get a good frame and body shop to check your alignment and frame out for sure, that is sketchy at best! I find old school frame guys with a really good machine might be best for this one!
The alignment shop I use found a ball joint going bad on my WRX, couldn't even tell driving it, but they wouldn't even align it, as they were afraid it could skew the measurements if it moved. New ball joint a week later and all was good.
Old Feb 22, 2014 | 07:06 PM
ej6sir-t's Avatar
bump
Old Feb 23, 2014 | 12:38 AM
BlackCatt's Avatar
More info would help. What suspension are you running and what settings? Also
have you got the lude on a hoist and done a real good inspection of everything?
Checked the alignments and the chassis?. If your stumped you really need to get
a good mechanic to look at it. Can't really diagnose the problem from a video man.
Old Feb 23, 2014 | 02:57 AM
holmesnmanny's Avatar
That looks like something going on with the radius rod. I've had two radius rods snap and the piece just sits in there it doesn't even fall out. Grab the radius rod in the front and see if it's loose. Just a thought.
Have you had an alignment done as everyone is recommending ? They can and SHOULD adjust the caster as well. A lot of shops think you can't adjust it but it's completely adjustable by adding 1/8 degree shims in between the radius rod and the subframe in the front.
Old Mar 14, 2014 | 08:59 AM
ej6sir-t's Avatar
No play in my radius rods. And the method your talking about for adjusting caster is for the base model preludes. To adjust caster on the sh models you have to swap radius rods..... Thanks for your help though
Old Mar 20, 2014 | 08:27 AM
ej6sir-t's Avatar
Bump
Old Apr 19, 2014 | 09:50 AM
ej6sir-t's Avatar
So the front tie rods (inner and outer) barely had any play but the boots were bad so I replaced them. At the same time I got new rear tires and an alignment. After that the problem has disappeared.
tegra_s2k
Suspension & Brakes
10
Mar 6, 2009 08:48 AM
ls_bitik
Suspension & Brakes
May 30, 2007 02:55 PM
burnitup
May 30, 2005 09:11 AM
x_tc-Dae
May 10, 2005 05:12 PM
PearlWhiteAccord
Jun 3, 2002 09:21 AM
