93 prelude having water/radiator fluid leak
I have a 93 prelude with a f22a1 motor and its leaking water/radiator fluid somewhere near the thermostat n tranny I changed the hoses up where the thermostat and under the fuel injector I changed the thermostat and checked the other hoses and I still can't find where its leaking from anyone else have that similar issue that can help me out please?
Re: 93 prelude having water/radiator fluid leak
you need to get it good and hot and have someone rev it while u take a good look at that area and hoses ...could be slight pinhole leak in a hose
when you changed the thermostat did you reseal the thermo housing? double check all hoses and tightend again, sometimes when the clamp goes into a slight angle it can leak through.
if that doesnt help, theres a couple small coolant lines that go to the bottom of the intake mani and then there's the connecting waterpipe that runs along the back side of the block from water pump to the t-stat housing, could be an o-ring went bad or pipe rusted.
it helps degreasing everything first and put it on stands and let it warm up and start checking with a flashlight
luvinthelude
02-11-2014 06:17 AM
hmtcrxsir
14
08-10-2006 04:12 AM
