ebrake issue (it's an odd one)
Old Jan 2, 2014 | 07:45 PM
Prudz_lude's Avatar
Default ebrake issue (it's an odd one)
When I pull my ebrake up on the passenger side is locking the brakes up. The driver side isn't doing anything. Both are hooked up identically and properly. Suggestions? I need to move the car down a steep hill and the brake booster/brake lines are removed at the moment due to an abs delete. It's being towed but I have to roll the car into my parkade which is steep enough to require brakes.
Old Jan 3, 2014 | 11:51 AM
crazes's Avatar
Moderator
Default Re: ebrake issue (it's an odd one)
Have you checked to see that the isnt maybe broken line there on that specific side when you pull up the brake?
Old Jan 3, 2014 | 12:22 PM
preludeNApower's Avatar
Bad caliper or broken cable, look to see if the lever on the caliper is moving when yo pull the ebrake.
Old Jan 11, 2014 | 05:44 PM
Prudz_lude's Avatar
Caliper is a fresh re-man. Piston is not seized in it, moves freely. When I checked the lines it is moving, but just enough that the pad touches the brake rotor. Not enough to lock it up. I'm going to try and fix it tomorrow.
Old Jan 11, 2014 | 06:46 PM
MAD_MIKE's Avatar
MM Gruppe B
If the hydraulic lines are not connected there is no way for the auto self adjusting screw jack to work. A trick that may work is to jam a screwdriver on the piston pad, while having another person exercise the hand brake.
Old Jan 12, 2014 | 10:28 PM
viper_boy403's Avatar
Yeah, like mentioned above the caliper wont adjust out without hydraulic pressure. You need to get the piston to come out to where it would normally operate before the ebrake will work
Old Jan 13, 2014 | 06:47 AM
motoxxxman's Avatar
I have this problem quite often with re-man calipers, even with hydraulic pressure, where the self-adjusting mechanism doesn't work. so I just screw the piston in or out til its in the tightest position that still fits on the rotor. if that isn't enough, I kept the stock brake pad shims and take up the small amount of extra space with one shim on one pad, or one shim on both pads.
Old Jan 13, 2014 | 01:46 PM
crazes's Avatar
Moderator
also do you have the dual proportioning valve to do this also?
Old Jan 16, 2014 | 02:33 PM
Prudz_lude's Avatar
Thanks guys for the answers. It ended up getting really cold so I never went and tried (unheated garage in -25degree Celsius) but will be trying this weekend. I have a civic prop valve in my prelude right now. It is out of an EG. I believe dual but idk if they are dual. I did not know that ebrakes required hydraulic pressure from the fluid to work. I ended up buying the brake booster vac tool so I can set the pin correctly. I'm going to get my brakes hooked up and bleed them correctly then see if the ebrake is working again.
Old Jan 19, 2014 | 08:41 PM
motoxxxman's Avatar
the ebrake does not use hydraulic pressure to operate, it only uses the hydraulic pressure to self adjust. once adjusted properly, you can literally remove the brake hoses from both of the calipers and the ebrake will still work flawlessly.
Old Jan 21, 2014 | 08:40 PM
Prudz_lude's Avatar
Ahhhhh ok cool thanks for the clarification.
deerman2701
Aug 11, 2011 01:14 PM
CRX_RR
Sep 25, 2008 12:49 PM
Nighthawk7thGen
Honda Civic (2001 - 2005)
Jul 3, 2008 09:11 PM
SiR HatchAlot
21
Nov 28, 2003 05:53 PM
GQ Cowboy
Jul 25, 2002 06:06 AM
