no start
Old Feb 13, 2014 | 09:11 AM
jsd's Avatar
jsd
Default no start
99 prelude wife parked in garage next day cranks no start checked timing,spark, and fuel all good. acts like its going to start but doesnt any ideas
Old Feb 13, 2014 | 07:19 PM
jsd's Avatar
jsd
Default Re: no start
got a p1382 code cylinder position sensor i guess that's inside dist.
Old Feb 17, 2014 | 05:43 PM
P. Hunter's Avatar
yes, clear the code and see if it comes back... if it does disconnect the distributor connector and test the resistance between terminal 2 and 4 (when looking at the connector they will be the two terminals on the right hand side) you should have 260-460 ohms.. if not then replace the distributor ignition housing ...
next you will check for a short to ground in the #2 and #4 terminal.. test each terminal for continuity to body ground.. if you have continuity then replace the distributor housing
after those two it get a bit more complicated with testing at the ECM and what not.. chances are you will find your results right away
Old Feb 20, 2014 | 04:29 AM
jsd's Avatar
jsd
i replaced the distributor the wiring was coming apart still no start
Old Feb 20, 2014 | 04:48 AM
holmesnmanny's Avatar
Turn the ignition on but don't bother starting the car. Check for battery voltage on the yellow/black wire at the distributor connector.
Old Feb 20, 2014 | 04:52 AM
98vtec's Avatar
moderator emeritus
Fuel, ignition, timing, compression. That's all that is needed for the engine to start. You are saying you have 3 of the 4 which are the common problems.
How did you check fuel and spark? You confirmed mechanical timing?
fear45
Dec 2, 2018 11:53 PM
jdmkidUK
Nov 30, 2011 05:49 PM
InvaderTrax
Oct 15, 2006 05:59 PM
boostmywankle
Jul 17, 2004 05:49 AM
