5th gen Struts
Old Apr 29, 2007 | 06:51 PM
Smokey5176's Avatar
Default 5th gen Struts
what are good struts to use with the TEIN S.TECH springs i was looking at the tokico hp or the kyg gr-2 struts are any of thoes good or should i look at something different???
Old Apr 29, 2007 | 07:12 PM
vinuneuro's Avatar
Default Re: 5th gen Struts (Smokey5176)
Those are horrible shocks. If you really want to stay low budget, Tokico Illumina. If you want to do it right..Koni Yellow or Bilstein Sport.
Old Apr 29, 2007 | 07:22 PM
InvaderTrax's Avatar
They're not bad shocks, they're just not high performance shocks. They're still a step above worn out OE. And if he's going with Tein S Techs, he's not after performance
Old Apr 29, 2007 | 08:17 PM
Smokey5176's Avatar
Default Re: (InvaderTrax)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InvaderTrax &raquo;</TD></TR><TR><TD CLASS="quote">They're not bad shocks, they're just not high performance shocks. They're still a step above worn out OE. And if he's going with Tein S Techs, he's not after performance</TD></TR></TABLE>
Im not really doing it for the proformance more for the looks im just adding bolt ons to my car also bout to get hondata chip, but i want some good shocks that are gonna last and not f**k my ride up so what do you think i should do?? Also should i stick whit the springs i plan on buying???
Old Apr 29, 2007 | 08:22 PM
vinuneuro's Avatar
Hp and GR2 are oem replacement shocks.
To the OP: if you want to do it right..get Eibach springs and Koni or Bilstein shocks. You'll be ecstatic with the results and it'll last.
Old Apr 29, 2007 | 08:32 PM
Smokey5176's Avatar
Default Re: (vinuneuro)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">Hp and GR2 are oem replacement shocks.
To the OP: if you want to do it right..get Eibach springs and Koni or Bilstein shocks. You'll be ecstatic with the results and it'll last.</TD></TR></TABLE>
Would the tein springs go good with the koni struts??
Old Apr 29, 2007 | 08:34 PM
vinuneuro's Avatar
Default Re: (Smokey5176)
eibach or h&r is much better. if you've already got the tein's just stick with them...they're not that bad.
Old Apr 29, 2007 | 08:45 PM
Smokey5176's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">eibach or h&r is much better. if you've already got the tein's just stick with them...they're not that bad.</TD></TR></TABLE>
Thank You im gonna go with the Koni i just found them on ebay new for 450 im about to order them now. Im also gonna go with the tein springs i head a lot of good things abo them.
Old Apr 29, 2007 | 08:56 PM
vinuneuro's Avatar
how much are you getting the tein springs? If you don't already have them don't get them. Go to eshocks.com. They have good package deals..Koni/Eibach, Koni/HR etc.
Old Apr 30, 2007 | 07:56 AM
HS2G's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Smokey5176 &raquo;</TD></TR><TR><TD CLASS="quote">
Thank You im gonna go with the Koni i just found them on ebay new for 450 im about to order them now. Im also gonna go with the tein springs i head a lot of good things abo them. </TD></TR></TABLE>
Do you already have the tein springs? You are spending around $500-600. Why not just get some Tien Basic coilovers for 675 shipped at optionimports.com. They are just basic coilovers without damper adjusters, but if your not gonna go for performance then it doesn't really matter. Plus the Tien Basics gives you an option of ride height adjustability. So I think its worth the extra $100 to be able to raise or lower your car anytime you want.
Old Apr 30, 2007 | 08:52 AM
vinuneuro's Avatar
Default Re: (HS2G)
All of you in love with Tein, read this:
http://www.wincom.net/trog/autocross_secrets6.html
Old Apr 30, 2007 | 10:05 AM
Masterbobo's Avatar
bilstein sport shocks are simply amazing, i give them a bold 5 star rateing!
Old Apr 30, 2007 | 03:31 PM
Smokey5176's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">how much are you getting the tein springs? If you don't already have them don't get them. Go to eshocks.com. They have good package deals..Koni/Eibach, Koni/HR etc.</TD></TR></TABLE>
I found them for 140
Old Apr 30, 2007 | 03:49 PM
LudeNEzz's Avatar
I have h&r's lowering springs with Tokico shocks on my 5th generation Prelude and it rides SMOOOTH!!!All my friends that have their suspension setup with other brands like skunk 2,Eibachs, Tein, even Koni Yellows on their 4th Gen Preludes, 5th Gen, Integras, Civics; envy my smooth ride. The handlin is really good also. H&R's with Tokicos, good combination
Old Apr 30, 2007 | 04:28 PM
Smokey5176's Avatar
Default Re: (LudeNEzz)
Wats a better strut to get koni or bilstien?
Old Apr 30, 2007 | 04:33 PM
vinuneuro's Avatar
They're both great shocks. Bilstein quality is better, but you'll have more support on ht for koni should you need it.
Old Apr 30, 2007 | 04:50 PM
Smokey5176's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">They're both great shocks. Bilstein quality is better, but you'll have more support on ht for koni should you need it.</TD></TR></TABLE>
I got a price for both sets there both 450 a set what one should i go with????(Koni Bilstien)
Old Apr 30, 2007 | 05:11 PM
vinuneuro's Avatar
I'm most def a fan of Bilstein. Look at the TOP drivers, and you'll find Bilstein, Ohlins, etc.
Old Apr 30, 2007 | 06:52 PM
Smokey5176's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vinuneuro &raquo;</TD></TR><TR><TD CLASS="quote">I'm most def a fan of Bilstein. Look at the TOP drivers, and you'll find Bilstein, Ohlins, etc.</TD></TR></TABLE>
Thank for your help im gonna go with the Bilstein struts the bilsteins also have lifetime warranty which is a good thing..
tpot90
Jun 14, 2009 01:03 PM
xclusionx
Sep 26, 2005 12:58 AM
305JDM
Suspension & Brakes
Mar 29, 2005 06:31 PM
wicked95
Jul 30, 2004 08:57 AM
beaterman
Jan 13, 2004 08:18 AM
