1999 Prelude Code 8 TDC sensor?
Old Apr 28, 2007 | 07:26 AM
o'malley_808's Avatar
Default 1999 Prelude Code 8 TDC sensor?
Hey just checked the cel flashes on my sisters 99 prelude with the dohc vtec h22. It flashed 8 times so i checked the cel code list and it said 8 was TDC sensor but I wasnt sure if the code list is different for obd1 or obd2. I know on my B16 the sensor was in the distributor is it the same on the h22?
Thanks
John
Old Apr 29, 2007 | 04:53 AM
Quan_97SH's Avatar
Default Re: 1999 Prelude Code 8 TDC sensor? (o'malley_808)
Hey, did you make sure it was code 8 and not 80 (EGR related). I just got this code recently and thought it was code 8 initially too.
Old Apr 29, 2007 | 07:08 AM
bluedlude's Avatar
Default Re: 1999 Prelude Code 8 TDC sensor? (Quan_97SH)
i believe the sensor you are talking about is on the oil pump.
Old May 1, 2007 | 06:17 AM
Default Re: 1999 Prelude Code 8 TDC sensor? (bluedlude)
Yeah im pretty positive it was code 8 plus the car is in limp mode and wont go over 3 grand so I think its more than likely the TDC sensor? Has anyone changed one before? Is it a pain in the A$$?
Old May 1, 2007 | 07:12 AM
bluedlude's Avatar
rather than be a dick and ask how damn lazy you are that you couldnt find it ill tell you. look at the back drivers side of the block, right on the corner and follow down the ONLY electrical connection that goes into your timing belt cover. really man, if you had only looked even 1 time you would have found it. now you can figure out what needs to be done to get to it.
Old May 1, 2007 | 02:05 PM
s_vares's Avatar
NO NO STOP EVERYTHING
TDC sensor is in DIstributor
the one on the oil pump is Crank Flutuation.
Old May 1, 2007 | 03:54 PM
bluedlude's Avatar
Default Re: (s_vares)
i dont know what you are talking about,
Old May 1, 2007 | 04:44 PM
s_vares's Avatar
im drunk
Old May 1, 2007 | 04:47 PM
bluedlude's Avatar
Default Re: (bluedlude)
me too
kizner
Jan 29, 2006 09:39 AM
LoseRPunKx182
Aug 25, 2005 08:53 AM
